Old 11-08-2015, 04:28 PM
FirebirdHank's Avatar
Default S-10 brakes in a first gen Fiebird
I'm considering the S10 rear disc swap and have been searching the forums but have a few unanswered questions.
Every swap I have seen has been on Lemans/GTO or 2nd gen F-body.
Does the first gen bird require the different backing plates due to staggered shocks or does the extra room because of narrower spring perches make that un-necessary?
If not necessary, does the 2wd or 4wd make for a better fit.
Any help or insight appreciated.
Old 11-08-2015, 08:20 PM
We have a nice setup that will clear the 68 and later shocks. Uses S10 rotors and Citation front calipers. Requires 15" disc rims, and ebrake drum is adjustable from the outside.
Old 11-08-2015, 11:20 PM
FrankieT/A's Avatar
Should be doable you just need one brake setup from a four wheel drive S10, and one set up for two wheel drive. Go on the V8S10 website and buy their spacers for 30 bucks and it's all bolt on. I have 30,000 miles on my set up and they work flawlessly. I have $350 invested in mine including drilled and slotted rotors.
Old 11-09-2015, 06:41 PM
How much for this kit?
Does it include parking brake cables?
I should add that I have a c-clip rear end, I know that makes a difference on some set-ups.
Old 11-09-2015, 07:37 PM
They are 235 for the brackets and parking shoes. Cable are extra - you can reuse your stock drum modified cables
Old 11-09-2015, 10:28 PM
So that is w/o rotors & calipers?
Really all I need is replacement calipers for the WS6/Seville units I have now. I can't get the parking brakes to work for more than a week without having to manually re-adjust them.
I thought the S10 system with the drum parking brakes would be a much better way to go.
Old 11-09-2015, 11:28 PM
David Jones's Avatar
My S10 conversion parking brakes work like a charm.
Old 11-10-2015, 02:00 AM
If you want replacement calipers try B&W brake in Missouri. Our setup all done is about $400 and no machine work required.
Old 11-10-2015, 10:57 PM
FrankieT/A's Avatar
Me too Dave
Old 12-24-2015, 06:29 PM
Just an up-date on this old post. I took the old calipers out and found that neither parking brake ratchet was doing its job.They were 4 years old and guaranteed for life so I returned them and got new (rebuilt) ones and before installing them made sure that the parking brake mechanism was working. Cleaned up a few things while under there and now I have working parking brakes.
Old 01-13-2016, 09:28 PM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
+2 on that
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
Old 01-17-2016, 03:12 PM
MNBob MNBob is offline
+3. They hold anywhere in any situation. With my factory setup, I could drive away and not know they were on. If I try that with these, the engine kills when I let out the clutch.
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
