winter upgrades?
Since the season is coming to an end, what upgrades do you plan to do?
My plans are new headers, engine diaper and new slicks. |
Get motor done and in, shocks, carpet, dash, digital dash for the logger, gear chane in transmission , new hood, new scoop, new radiator, fuel cell, glass , new front lower valence, msd grid, wiring, converter, weight loss on car and driver. Haha wow seams like a lot when its in text, but it feels like just a winter tune up . Lol
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
A pair of 88 MM on Alcohol.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Check /replace bearings, fix all vacuum/oil leaks, idle bypass check valve for injection, loosen converter and replace broken spare rear end gears. Short and simple this year.
I'm going to finish the upgrades I didn't get done last winter.
Getting a set of headers built,having a rack&pinion installed and a cm steering column to try and take some weight off the front of the car....and most likely a aluminum block
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.854@160.12 in Brainerd MN 7/2024 |
I ordered new valve covers...
A new block to replace the cracked one...hopefully this winter.
I am trying to get my DOUG NASH/WARRIOR/LS EFI intake finished and checked for port fitment and valley pan clearance before spring. Possibly could 'dial the thing in' somewhat on the convertible if I get the Tanks,inc gas tank installed with the Aeromotive parts and Bosch parts. right now designing/fabrication of the fuel rail brackets and the fuel lines/regulator mount seem to be the next step.
Tom V.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
He's got a CNC so we can make it say pontiac on the valve covers LOL
Going to the dark side, I like it. No more bottle fills.
Funny part is that motor is more legit pontiac than any motor in this thread probably. Them heads have a recognized pontiac part number.
After I hit the powerball!
That's what I'm doing with mine...
The only way lil jack won't be filling bottles is if he gets a vasectomy.
That's funny!
I think I still have the stock points distributor, crankshaft bolt, oem starter bolts and water filler neck???
