Old 10-08-2015, 12:05 PM
M.L. M.L. is offline
Default 64 Bonneville TV rod....newbie here
Hallo!
My name is Markus, and I'm living in Germany. After driving some old Harleys I decided to buy a 64 Bonneville 4Drht as a daily driver, because modern cars are boring!
After some years of "happy driving" the 389er engine past away...
so I decided put in a 461 stroker. Now I have the problem to adjust the TV rod.
The transmission is a Super Hydramatic.
I don`t have a manual and in the www I only found an adjustment for older transmissions with a TV cable.....
I would be very thankfull if someone could help me!!
Markus
Old 10-08-2015, 03:55 PM
63gpman's Avatar
63gpman 63gpman is offline
Welcome to the forum, would love to see some pics.
There are a few discussions about this on the site, the search function can help you find a lot of great info. Here is one that may be most helpful. http://forums.maxperformanceinc.com/...=tv+adjustment
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 10-08-2015, 05:11 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
461 in front of a Super Hydro... bet that digs out in low!
Old 10-08-2015, 10:18 PM
Engine-Ear's Avatar
Yes, welcome to the best place on the web for Pontiac tech and e-friendships (that often turn in to long term friendships after a weekend at Norwalk or a POCI convention)!
63PGMan's link is a good one. Also get on ebay.de and buy a "Hydra-Matic Shop Manual" for '64...'62 or '63 probably also have the key info you need if a '64 is not found.
And may I also suggest this: http://rustbucket.de/
bis dann!
Old 10-09-2015, 04:54 AM
Alf ista's Avatar
Alf ista Alf ista is offline
Welcome to the forum Markus. Show us some pics of your big car!
'64 Grand Prix in Yorktown Blue on 8 lugs. 400 th400 combo.
Old 10-09-2015, 05:17 AM
Thank you for you answer!
here some pics....
Old 10-09-2015, 09:31 AM
Thank you for your answers!!
Here some pics....
ID:	409925   Click image for larger version
ID:	409926   Click image for larger version
ID:	409927   Click image for larger version
ID:	409928   Click image for larger version
Old 10-09-2015, 09:34 AM
63gpman's Avatar
OUCH!! I guess you had good reason for the 461!!! Looks like a nice ride other than the prior hole in the oil pan, bet that made a lovely sound when she let go!!
Brad Hansen
Old 10-09-2015, 09:58 AM
My girlfriend was driving it about 160km/h on a highway and I was right behind here in the Roadrunner. I could`t see anything, because of the oil fog....
Yes, she told it was a frightening "sound"...
NO, its was not a long time "high speed running"!!!!
Old 10-09-2015, 10:08 AM
Txbobcat Txbobcat is offline
Nice looking car and welcome
Old 10-09-2015, 10:55 AM
pfilean's Avatar
pfilean pfilean is offline
Sorry about the old 389. They were good but that is obviously done for.
Here are a couple of pages from the 61 manual on the TV adjustment. I think it is the same as 64 but should get you by until you take Engine-Ear's advice and get a manual.
Can't seem to get it to take two pages at the same time. I'll try them one at a time.
Old 10-09-2015, 11:03 AM
pfilean's Avatar
File size bit me again. I'll send the first page in halves.
ID:	409934   Click image for larger version
Old 10-09-2015, 11:39 AM
Engine-Ear's Avatar
Great DarkSider, M.L.!
That old oil pan is garage art.
What intake manifold and carburetor are you running now? I think the T.V. adjustment will require you to have the rest of the original linkage on it (the intake) for success.
Post a pic of the driver's side of the engine (without the air cleaner) so we can see what you have there.
Old 10-09-2015, 11:46 AM
Thank you very much!!!
That is what I need!
Old 10-09-2015, 11:55 AM
No garage art....my girl friend will build a coffee table with the block and the broken parts!
Intake is a Edelbrock Performer 2156 with a 750 Quick Fuel.
ID:	409936   Click image for larger version
Old 10-09-2015, 04:11 PM
stevep's Avatar
stevep stevep is offline
I would shorten the rod that goes from the carburetor to the upper bellcrank. You will have to extend the threaded portion to get the correct adjustment.
I have had to do this anytime that I have used 65-later heads.
Old 10-09-2015, 04:48 PM
Thank you for the advise!!! Have 6x-4 heads.
