Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I picked up a 1989 pontaic T/A today that has a loose steering wheel. at first I though it was the internal bolts backing out like so many GM columns have done. Then I realized it was just the shaft moving. I took it most of the way apart & found that there is a back bearing that the plastic ball retainer has broke & allowed the balls to roll around wherever they want causing the movement.
Does anyone know if I can buy this bearing? I will have to see if I can buy the puller to get the pivot pins out somewhere as this is as far as I can go right now. I drew an arrow the point to where the back bearing is located behind the housing. Thanks for any input! 68RT
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
Well, I got the rest of it apart. Talk about weird, It would appear to me that the lower bearing win installed backwards! How could this be? The column appears to be virgin until I got into it, If somebody had it a apart, they left no evidence.
Now I need to figure out where to buy the bearing & see if I can get the race out. Seeing its in backwards, there nothing to tap on to drive it out.
I heard good things about these folks - CJ's Rods and Machines in NC
http://cjsrods.com/cjs_rods_001.htm You may want to check them out. |
A little pricey, but I've always used this kit if I couldn't get a good set from a salvage yard.
http://www.ebay.com/itm/GM-Steering-...a46cf7&vxp=mtr As far as the race, I just gentle peel the plastic retainer with the bearings off the new, and snap them in to the old. Make sure they are packed with grease to stay in the retainer better.
2-1962 Lemans convertibles 4cyl, auto 1962 Tempest safari wagon (running project) 1972 455 Formula (tribute) 1962 Skylark convertible 215 4-barrel , auto 2009 G8 Sport red metallic, Onyx leather Whatever else that make my way into the driveway |
Thanks guys, I ended up buying a used bearing & just used the plastic retainer. The grease was definitely the answer to putting it together. I should have posted back to update where I was at. The rebuild kit was available from GM, but it included extra parts I didn't need.
Thanks for all the help & suggestions!
