73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-28-2015, 12:25 PM
sdx455's Avatar
sdx455 sdx455 is offline
Default dash panel
I already changed out all the car wood grain, door panel/console to a carbon fiber look with self applicaid vinly. The dash is hard. I peeled off the woodgrain with a heat gun and it left a sticky bumpy base . so I am making plastic inlays to glue my carbon fiber to . traced and cut them out with razor knife
73 GTO 455 TKO 600 3.90
Old 07-28-2015, 12:27 PM
sdx455's Avatar
I am also painting it with spaz stick chrome , this is a spare dash bezel , not the one in the car
Old 07-28-2015, 12:28 PM
sdx455's Avatar
Here is a roll of the carbon fiber stuff. Its a little more modern than the wood look
Old 07-28-2015, 11:55 PM
cdrookie cdrookie is offline
hurry up, i want to see the finished result!
Old 07-29-2015, 12:37 AM
Alvin's Avatar
Alvin Alvin is offline
Interesting & subscribing
Old 07-29-2015, 12:38 AM
I tried to remove the wood grain stuff off my dash panel & it did the same thing, it left the glue behind. What I have tried on a couple of them I have is ,, I went to the hardware store one that sell counter tops & cabinets & got some of the formica that goes on the countertops & cut it to fit. I haven't found the correct style yet but cutting out the pieces for the panel is pretty easy & then it sticks down easy with some adhesive like the stuff for headliners. Those shops have lots of samples to use so you can get just about any pattern you want.
Old 08-04-2015, 09:35 AM
sdx455's Avatar
got some work done , a little bumpy the vinly is old and I had to use some 3m glue to get it down
ID:	404379   Click image for larger version
Old 08-04-2015, 09:36 AM
sdx455's Avatar
pics of the doors and console
ID:	404382   Click image for larger version
Old 08-04-2015, 09:38 AM
sdx455's Avatar
This is on a spare dash , I will be painting the one in the car
Old 08-04-2015, 08:31 PM
I'm not a fan. I think that it is to much black on the face of the panel. I have always liked the wood grain because it makes it pop out at you. I'm glad for you if you like it as it is a new look for the car. But I guess I'm just old fashion as the wood is my choice.
