Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
- Ram Air Restorations aluminum '61/'62 Super Duty exhaust manifolds jet hotted dark grey inside and out + gaskets - no collectors manifolds only - bought new this Spring - $1600
- 425s passenger’s side exhaust manifold and elbow - $300 - complete ‘62 green interior components never installed includes SMS door panels, carpet, head liner, standard seat material with SMS embossed seat back panels, NOS floor mats front and rear, package tray - $750 - #9770716 heads bare - $550 - #77 heads complete - $550 - #670 heads with guide plates and screw in studs - $350 - #16 heads ‘68 big valve with guide plates and screw in studs - $350 - gto cowl and grill surround - $25 ea. - 65> ansen bell housing bottom only - $50 - ‘62 dash, grills, headlight bezels - $75, $25, $10 ea. - various cams and lifter sets some with springs - Lunati 07703, Crane h296-2, Summit 2802 and 2802 - new never installed- $75-$150 - Lunati full 1.65 roller rockers - new never installed - $200 - PRW roller tip rockers and poly locks - new never installed - $75 - Comp Cams roller tip rockers and poly locks - used - $25 - factory screw in studs - $10 set - 6cc 421 pistons - std bore - matched set - $100 - 6cc 421 pistons - std bore - mixed set - $50 - 12cc dished 428 pistons - std bore - matched set - $100 - 12cc dished 428 pistons - .030 over - $200 - 425a forged rods - $40 set - cast rods - $20 set - ‘64/’64 GP back glass - $45 - ‘63 big car std steering wheel and horn button - $35 - ‘65 GTO cowl and grill surround - $24 each - 8 qt. deep oil pan - $50 |
I forgot to list the 15" 8 lug set
- Four (4) BOP 15" 8 lug rims with new Coker 7.50x5 thin ring whitewall tires mounted and balanced, and new trim rings, never installed on a car - $1250 - Restored '63 8 lug center caps - never installed - these look like jewelry - $400 Nothing wrong with the above I was going to put on a '63 Catalina but have decided to go with 15" steel wheels and poverty caps. |
what color is the 63 steering wheel, and condition? also looking for a set of trunk hinges for a 63 Cat....
pm sent
Interested in the oil pan, can you post a few pics.
![]() Quote:
I have hinges on a '64 GP parts car sitting in front of my shop but would not be able to remove them until after Norwalk. |
This is not a real SD oil pan. This pan was made up in Canada and is very well done but in order to make it look like a real SD pan someone would have to take a mig welder, or 110 stick welder on low amps, and put some messy weldment strips in the appropriate places. I had planned to do this but found a real pan so am selling this one.
Pictures of SD exhaust manifolds. I bought these this past Spring and they have been on my car in a left bay with the engine idling and the car driven back off the ramp and back on to do things. They clear all the way around but are a very tight fit as the pictures show. The driver's side cross member clears without being notched but just barely. The only reason I am selling these is because I lucked out and found some original cast iron versions.
![]() Quote:
I about to get in trouble here on the 3 day rule so will not post any more. This stuff will be at Norwalk Friday morning. |
The comp cam roller tip rockers, are they 1.5 or 1.65?
Pm sent on 2802 cam and prw rockers/locks.
If it ain't broke, fix it 'till it is |
Both the new PRW and the Used Comp Cams are 1.5.
Interested in the R side exhaust manifold and elbow. Could you hold it for me til Thursday when I get there?
Thanks Chris |
PM sent!
Hello I am very interested in some of your parts please let me know if you can reply to my private messages, are the parts still available?
Thanks! |
pm sent
color me gone |
