THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
4 QJs on one intake
neet..but why?..i like weird stuff..but why put yourself thru all that? seriously..whats the theory be hind it
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
He's got a problem with 5&7 backfiring through the secondaries. Nice job on the intake manifold, looks like it's cast aluminum. The olds guys have a few innovators in their ranks I see.
The revision makes a fog of gasoline over the carbs when all 16 barrels are fully open, guessing just too much open area for the size of the engine and there is no vacuum. Even if they are 700 CFM each that's 2800 CFM. Since there is no reports on performance, and this was done in 2006, I'm guessing it was a failed experiment. |
As a q jet fan that's f'n cool I'm jealous
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." Thomas Jefferson |
Tighten the secondaries flaps to limit the cfm, I think thats an offenhauser set up, cool looking, but would be a nightmare to set up. this is more like it.
https://www.youtube.com/watch?v=nyyRoaeujiAram air II drag car Last edited by post toastie; 07-19-2015 at 04:49 PM. Reason: spelling |
Individual runner (IR) manifolding pretty much changes all the 'rules' on how much carb you can put on top of an engine.
For example take a look at the 289 Cobra with four 48IDA Weber 2-barrel carbs. Each carb has two 48MM throttle plates and 45mm venturies, that's as big as you can go with the replaceable venturies on the 48IDA. Each carb is rated at around 583 CFM. So 4 of them would have 2332 cfm, and yes I do realize 2-barrels are rated differently than 4-barrels. In reality that's barely enough carb for that 289. I used to run two of the 48IDA carbs on IR manifolds on an air-cooled 1835cc VW flat-4 that was my daily driver about 37 years ago, using 37mm venturies. So that's a 112-cube engine with about 1000 cfm of carburetion. It had great low-end pulling power and fantastic top end, it ran smoothly at a 500 RPM idle speed and pulled nicely from 1800 all the way to 7000+ RPM. These Weber carbs are infinitely tuneable and are specifically produced for use on IR manifolding, a Q-jet is designed to run on a dual-plane intake and is really not well-suited for use on an IR intake setup. None of us have IR manifolding on our Pontiacs or any other American V8. They either have a dual-plane intake where only one half of the 8 cylinders can draw from one side of the carb or a single-plane intake where all 8 cylinders can draw from both sides of the carb at the same time. You really are not comparing apples to apples when comparing carburetion on an IR manifold to carbs on a single-plane intake with a common plenum. IR intakes require a lot of throttle area, each cylinder draws from one individual throttle bore. So the intake on this Olds has one primary and one secondary separately piped into each cylinder, allowing about 375 cfm total to each cylinder with it at WOT. Probably about right, but again the Q-jet just isn't designed for that type of manifolding. I'd bet a single Q-jet would easily whoop up on that 4-carb setup. But it is neat and looks quite impressive. You'd surely be the only guy at the car show with one.
Dual Q-JETs was sufficient for me. Do like the video.
The vapors exiting is typical of a Q-Jet getting crosswind. Just try putting a leaf blower toward an idling Q-JET (no air cleaner ) and see what mess happens. I did.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I bet it's a bitch to find that air cleaner. Damn cool though.
What is up with all of the fluttering of the secondary air valves at wide open throttle?
I hope my q-jet isn't doing that under the air cleaner.
1967 Pontiac GTO 1965 Olds Cutlass 2014 Ford Mustang ----------------------------------- GTO-The Great One for 1967 ----------------------------------- |
OP Video filed under "Wretched Excess!"
Understandable that sustained WOT is needed to keep them open. We saw just a bunch of brief WOT blips, relative to a 1/4 mile run.
IR manifolds require more tuning than most are willing to do for street vehicles.
My experience with an IR had two 500 CFM two-barrels on a 2000 cc high RPM 4-cylinder engine. Factory installation, and it worked VERY well; but I would have not liked to do any tuning, other than the necessary synchronization. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
Imagine what that sounds like in person.... with your foot on the pedal..
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
Because he could and it looked damned cool!
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
Agreed
Exactly what I was thinking, it's creating a partial vacuum.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
