any body run or have run a crane fireball h 294b cam. 294/304 .488/.508
have a 421 4 speed or maybe a 400. just wondering if it a good go fast cam
64 tempest wagon 421 gasser ![]() |
Yes, one of the best street performance cams ever! IMO
What I am going with in my 64 GTO tri power 389 project.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
What are the .050 numbers?
I bought a used engine that supposedly had a crane fireball cam in it back in the seventies. It was a 400 with a torker intake. That thing didn't have much off idle, but up above about 4000 it pulled hard.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
This may sound sad to some, but have had the same cam in my street 69' F-Bird for ~ 30 years (put in 85' I think). Runs 11.60's @ 117.
I feel there is more room to optimize to achieve a lower ET if / when I get off my duff.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
I don't know your combination but I don't think 11.6 @ 117 sounds bad at all. There are a lot of guys going slower with hydraulic rollers.
Is this cam from the Fireball Roberts era? Or just marketing?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
I recall the 294 B was desired over the 294 A.
In the 80's I got a used 294 B and with 1.5s, and a Torker I, it ran okay in my 428 TH400 & 3.90/4.11 rear. Next step was the ISKY Magnum 320 HYD with 252/252 @ .050 : what an amazing full range cam on the 428 @ 455. I attributed the amazements to the 104 LCs. Tried customizing a couple Ultradynes with 104 LCs. And installed with 4 deg adv. --> Does anybody run Street/Strip with 104 LCs? Last High-Compression step was the Lunati 30705 (SPC2-320) with 245/255 @ : best off-idle I've felt on the 455 ran 11.0 ET, 123 MPH with ported D-port iron. Simply the best off-idle, cleanest plugs, temps, manners, performance from my efforts. Other folks have their favorites, perhaps same or better, maybe worse. Since gone to low compression & cam in Sig with last outings showing 12.2ET in 3850 Lb on 89 Octane. ![]()
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I used a Crane Fireball cam in a 1979 Trans Am a 400 4 speed with a street dominator Holley intake 750 Holley carburetor 4:11 rear headman headers car had a great rump to it and ran 11:70's and could drive it any where
That series of cams was developed in the late 1960's early 1970's. I think Fireball Roberts had met an untimely end in a Ford Stock Car a few years earlier. Not a bad cam choice. Much better stuff was devevoped by Harold Brookshire around the same time. If you have good heads, it would benefit from some additional rocker arm ratio from a 1.5. If you already have one, I would run it.
Nice cam in a 455, it will also like at least 10 to 1 compression.
I've known several folks to use that cam in 455 builds with well prepared iron heads, and all of them ran well into the 11's with their cars...........Cliff
Those specs sound very similar to the current Crane HIT 284281 I have in my 455.
I loved the old Fireball in my 69 Judge. Back in the early 80's nobody could get past me. If I could find another one I'd use it again.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
