Window net bottom attatchment
Is this not legal as is not considered permanent?
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
If it's not legal, I would guess it's because the attaching belts wouldn't prevent a hand from going through (between the net and the cage bar). As I'm sure you know, they sell nets with slanted bottoms to conform to the cage bar. Even with those, you have to wire the front bottom of the net to the cage, so it doesn't allow the net to slip backward at the bottom.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
No the straps go around the door bar no part of the net or attaching mount can be outside of the cage
OK, thanks.
This is how I did mine on my GP. I think it's legal? No tech guy had an issue with it yet. Door bar goes on the outside.
Here's another pic.
Jim
