Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
NP435 to BOP bellhousing
I've looked online and cannot get a clear answer. Does the NP435 Ford bolt pattern fit a BOP bellhousing with 2 patterns drilled into it?
The 1986 Ford I have is the best $800.00 I have ever spent. That said, if and when the engine goes, instead of rebuilding the 300, I was thinking dropping my soon to be swapped 400 "557" block into it as a upgrade. By then I will be out of NJ and in a state with less strict emissions. Thoughts?
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
we used a ford toploader with the other holes in the bell, not sure about a NP trans. if the pattern is the same as a toploader dont see why not....
A little Googling and found this
"From what I can find, the NP435 trans uses the Top Loader to bellhousing bolt pattern. " "I've also found info that states the older TKO uses the same bolt pattern as the Top Loader." "This site here was helpful for info on the NP435. It states: "The Ford NP435 has a 1-1/16" diameter, ten spline input shaft that has a stick-out of 6-1/2" from the front face of the transmission. The pilot tip of the transmission measures ~17mm." The New Process 435 Transmission - Novak Conversions " The issue may be in that Input Shaft length, spline and pilot tip dims. I believe the Ford Toploader 3 speed Pontiac used in the mid to late 60's had a GM specific input shaft made for them to work.
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd Last edited by PONTIAC LARRY; 06-03-2015 at 03:03 PM. |
When we used a toploader we used a special pilot bearing that fits in the torque converter pilot hole. That fixs the input shaft length problem.
