pwr window motors
I changed out the window switches and it didn't help . pulled the motors and want to replace them , will the ones Ames sell fit ? here is what came out
73 GTO 455 TKO 600 3.90 |
I opened them up , full of gunk and bushes were toast . they looked dipped to prevent water damaged
I would buy gennie GM if at all possible
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
yes ,but where can I get a gm replacement . I could use the switches and connectors too . the ones I bought from electric life ,are plastic and smaller wire size
Check your connector style. These A bodies differ from most GM models in that the Left motor to fit most GM cars fits the right door on these A bodies, and vice-versa.
http://www.ebay.com/itm/2-DELCO-POWE...ht_8417wt_1362 http://www.ebay.com/itm/NOS-1977-79-...ht_8425wt_1362 These will work with some mods, or you can swap the guts out to your housing. The dip they used is very similar to the vinyl tool dip commonly available to seal the motors up. The OE numbers are 5045664 and 5045669. They are quite expensive, but do not settle for cheap offshore replacements.
Intresting ,I noticed mine had a big R stamped on it , I thought it meant right side but it was on the driver door
when I opened it . I could not get the motor shaft to come out from the gearbox , but the winding side came out and popped the brushes out and was very difficult to get it all back together. I was thinking if I had to I could put new motors on my gearboxes . Is there a secret to getting motor shaft out of the gearbox? without messing up the armature side
Saw these before on Frank's as a FYI for you. Interested in $$$ costs for replacement or repairs to your power motors...we have same on our '73 Grand Am
Edit: Pulled out my copies of MOTOR Auto Repair Manuals and surprised to find no power window service information FWIW. Last edited by Alvin; 05-29-2015 at 12:59 AM. |
Ok got it apart you have to hold the armature and unscrew the gearbox worm gear ,looks like I could switch gearboxes on motors if needed
stamped part # looks like 5045535
I bought the 2 from ebay , neither seem to work what could I be doing wrong , just hooked them up 12v to test . put a tester on them They have continuity
Perhaps this will help?
Remembering out loud: to power my '79 TA electric windows up & down (while in dry dock in garage) was told trick was to apply power only to motor and ground other battery cable to door frame. |
yes , you have to ground the housing . the switch only applies power . So I grounded it to neg, side of batt . and worked . then I switch out gearbox with my gearbox it motor fit perfect . installed it back on car and doesn't work . Have to pull it again I was thinking maybe door does not have good ground .
Do the dome lights dim when using the switch?
I am not sure , if dome lights dim .
I was able to install the motors from the ebay ones to my gearbox no problem . It seems the new 2 button switch I bought has a ground wire . when I attach that wire windows would not work . put tester on it and it gets 12v. when I press the switch and would ground everything out . old switch did not have the ground wire . left off. windows now work with the new motors
Glad it finally worked out for you.
