THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Anyone here use a Quincy air compressor? I just picked up a near new Qt54 on Craigslist for a good price. I drained the oil prior to transport and need to refill for start-up. I know for warranty purposes Quincy insists you use their own private label synthetic which is sold in ISO ranges based on ambient air operating temps. Any other options I should consider? I used simple ND 30 weight in my CH cast iron series but maybe it's best to stick with synthetic for the Quincy.
Andy North Carolina 1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later |
Like you I use nd30 weight - in an 80gal 7hp compressor with a cast iron 2 stage pump which now has thirteen years on it with no problems.
IMO Quincy is just trying to sell oil to you but during the warranty period I would use what they tell you to use. |
Quincy compressors are very good. I have 3 at work, 2 of them run almost constantly. I use Mobil synthetic compressor oil on them.
Since I bought the compressor used, Quincy won't transfer the warranty. So I can use whatever I want. This will sit in an unheated garage and I read the synthetics withstand winter/summer temp swings better. Not sure how true this is.
The Mobil Rarus stuff? 30 weight? Unfortunately the only place I know around here that carries it is Grainger and it's more $$ than the Quincy Quincy Cip oil.
![]() Quote:
![]() 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
Yes, It is the Mobil from Grainger, and it's expensive. I just took rod bearings out of one of the compressors and they looked great, after AT least being in service for over ten years cycling on and off a lot 24/7. It sounded like a rod knock in the compressor but was a loose flywheel.
I have been in the compressor business for 37 years. Simple 30W ND works great in a recip, change it once a year for home use and 2 X for extreme duty like a full time body shop.
There is no big advantage to synthetic in a recip, but for a screw compressor, that is a totally different animal and you want to use a good polyglycol synthetic. I tell my friends and customers, buy a good slow speed (900 rpm or less) recip over a screw unless you plan on running the wheel off it. T he exception to that is when you get above 10-15HP in a single unit. |
