Old 04-15-2015, 01:58 PM
Terry M. Hunt Terry M. Hunt is offline
Default Photos needed
Could somebody post some pics of a full size factory Manual Trans Tri Power linkage? I specifically need to see the driver side showing the return spring and exactly how it is attached at both ends. Converted mine from a 4 BBL auto and not sure I have the linkage/return spring set up correctly.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 04-15-2015, 02:18 PM
Keith Seymore's Avatar
Terry - I think all of my big car tripower photos are of auto trans vehicles.
K
Name:	GP underhood (ref3).jpg
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 04-15-2015, 02:47 PM
ho421's Avatar
ho421 ho421 is offline
I have converted to the later style (safer) linkage but believe this to be correct after posting the same question a few months ago. 63 manual
Old 04-16-2015, 07:59 AM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
Good info I hope to need in the future
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
Old 04-16-2015, 10:33 AM
Engine-Ear's Avatar
Default What year?
What year is preferred?
Old 04-16-2015, 05:01 PM
My goof. I'm looking for photos of a '65 manual trans Tri power set up. The pics provided thus far are also very useful and appreciated.
Terry Hunt
Old 04-25-2015, 06:48 PM
Anybody got a pic of a '65 set up they can share?
Terry Hunt
Old 04-25-2015, 07:04 PM
tom s tom s is offline
Check pontiactripower.com.Mike has a pic of a 65 with the return spring shown.Tom
Old 04-25-2015, 11:14 PM
Tom, I must be missing something. I spent a fair amount of time searching at the site you suggested, but only saw pictures of '65 GTO Tri power linkage, not full size car.
Terry Hunt
Old 04-25-2015, 11:20 PM
Might send him a email and see if he has a pic of the 65 big car.I have not seen a 65 big car throttle bracket.On the GTOs the spring goes to the bracket.Tom
Old 04-26-2015, 12:09 AM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Parts book
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 04-28-2015, 10:08 AM
65WJ's Avatar
65WJ 65WJ is offline
I am a bit late to the party
I have the trii power off my HO
Not sure if it is concours correct or not but tonight I will take a picture and post
patrick
Old 04-28-2015, 08:55 PM
65WJ's Avatar
Default pic
she is old been sitting since 90 iirc
hope this helps.
patrick
Old 04-30-2015, 01:11 PM
Default photos needed
65 WJ thanks for the photo you provided. That is pretty much how I had my return spring attached, but the throttle linkage pivots on a bracket attached to the firewall and the pivot arm attached to this bracket has three holes drilled/punched in it horizontally that appear to be intended as a return spring attachment point. I moved my spring to one of these holes, with the other end attached to the small upright bracket that bolts to the intake (near the bracket for the power brake vacuum hose as shown in your photo). This removes any stress generated by the return spring tension from the throttle arm on the center carb, which seems like a good thing to do, but still not certain it's how the factory did it. My return spring is different from yours also, which appears to be the one I'm familiar with for use on GTO's. Mine has coils from end to end with no straight sections on either end as the GTO spring has. The wire diameter is much greater also. LASjayhawk, it appears you were trying to post info from a parts book, but I'm not able to access them. Nothing appears to be attached to your post.
Terry Hunt
Old 05-06-2015, 10:11 PM
LASJayhawk's Avatar
Repost.
Old 05-08-2015, 10:14 PM
LASJayhawk, kudos to you for the exploded view. Exactly what I needed. Many thanks to you.
Terry Hunt
Old 06-11-2015, 12:12 PM
19652plus2 19652plus2 is offline
My car ('65 Cat 2+2) is long gone, but here are pics of the OEM throttle return spring bracket. According to my research, it was the same for 4bbl and tri power cars. The illustration pic of the bracket is from page 6B-2 from my 1965 PONTIAC CHASSIS shop manual. If anyone is interested, I still have this bracket. You can simply have it for the cost of shipping.
ID:	400192   Click image for larger version
ID:	400193   Click image for larger version
Old 06-19-2015, 09:58 AM
65 Cat 2+2's Avatar
65 Cat 2+2 65 Cat 2+2 is offline
Default '65 manual Tri-Power
Looks as if you got your answer already, Terry, but this may help...
Name:	421 Engine.jpg
1965 Catalina 2+2 421 Tri-Power, 4-speed, all original except paint -
AACA Grand National Sr. / POCI Champion - 13.71@104mph 1/4-mile
1958 Bonneville convertible - AACA / POCI survivor awards
1963 Catalina 2-door hardtop - 10.91@124mph 1/4-mile
1933 Pontiac 2-door Sedan street rod project (in progress)
1962 Corvette 327/340hp, all stock
1963 Studebaker Avanti
http://www.1965Pontiac2Plus2.com
http://www.Pontiac2plus2Registry.com
