Old 03-29-2015, 01:45 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
Default IA II blocks & Roller cam bearings
I'm currently upgrading an IA II block to roller (50 mm) cam bearings. I was wondering what others aware doing to insure adequate oiling to the timing chain area? It looks as if the factory design (hole in the retainer plate) will not provide much oiling to this area. Is mist/splash enough, or are you drilling a small hole in one of the front galley plugs? Thanks, Bill--
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
