Firebird Sprint 4 speed conversion question
I'm preparing to convert my son's 68 Sprint 'Bird from a column shifted 2 speed automatic to a 4 speed on the floor.
Here's the plan so far and what parts I have acquired: Use a 1975 Borg Warner Super T10 I already have. My shifter set-up is one I previously modified to fit in a first gen firebird original 4 speed hole, works with factory console, tried it before. I bought a used OHC6 flywheel and bellhousing from a cammer guy on firstgenfirebird. I have the correct clutch fork, GM part number: 9787069 Now for the questions: Which clutch and which clutch release bearing do I need ? I know I need a 26 spline clutch disc since the BW super T10 has a fine spline input shaft, but otherwise ? I believe there are two clutch sizes available ? 10.5" and 11" ? Also, I have read somewhere that a 6 cyl flywheel is "stepped", mine does not look stepped, it seems flat. |
It is a 10.5" Clutch, I have never seen a stepped flywheel on an OHC-6. If you are interested I have a New Hayes Clutch pressure Plate and Throw out bearing I was going to use with a Muncie M-20 with the fine spline input shaft so it is a 26 spline clutch plate. It was installed in the car, but the engine was never started, Currently still bolted to the OHC-6 that came out of my old 67 Lemans. I will sell it for 1/2 of the current new price from summit. Let me know if interested and I will get some pic;s this weekend.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Do I understand you don't need to search for a specific application ? Like there are four different applications: 11" or 10.5", and 10 or 26 splines ? That makes sense, but what about the "right" throwout bearing, how does one figure out which one he needs ?
FWIW;
Everything borrowed/matched to the GTO standard app/spec 10.5 (10.40) HD app was/is 11" you don't need this. I would consider the original FW as stepped. I think it was nothing more then to save on some machining?, Once had one machined and they cut it flat I experienced no issues from this.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 06-12-2015 at 05:59 PM. |
Your ST10's first gear is high for a 6 cyl. The original trans has a first gear in the 3.'s But if thats what you have.....
Agree, forced to install a 2nd design T10 behind a OHC-6, I'd consider the 3.42 1st gear ratio 2nd design T10 out of an '81 305 4spd T/A or Z28. Using an oem '68 or '69 Bird Hurst 4 spd shifter, going to face some real challenges adapting the shifter to the different spread mtg bosses of the late T10.
Why not put a t5 in it? You are converting from auto so you have to cut the floor for the shifter anyway. Very straight forward and parts can be found cheap and easily. Seems like a no brainer, but thats just me...
Running a t5 with 4.11 gears and still runs about 1800rpm at 60mph. What else can you want lol?
1969 Firebird OHC 6 Sprint Clifford Intake, Clifford Shorty Headers, Crane H320 Custom Grind Cam, Edelbrock 550CFM, T5 5 Speed Transmission (.63 OD), 8.5 10 Bolt Posi 4.11 Gears. |
Looks good,
Always like the no nonsense look of console-less interior.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
