Old 12-13-2014, 03:25 AM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default Firebird power brake booster inside
Hey guys ....
I bought an new power brake booster for my 77 Firebird ...
My old stock is leaking at rear ....
The new one arrives and i compared vs the old one and i saw that the center plastic shaft leading is broken during transport ...**** !
I`m from germany and return it to US is half of price of the new part.
So here`s my question:
Can i swap the broken plastic leading of the shaft from my old Stock PB in my new Power Booster ?
I know i can open the case with turning it ...but don`t know if i can reuse the gaskets a second time and all the things ..
Any idea if this will work to swp the black plastic leading ....?
Thx , Bjoern
ID:	384306   Click image for larger version
ID:	384307   Click image for larger version
ID:	384308   Click image for larger version
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 12-13-2014, 10:04 AM
67drake's Avatar
67drake 67drake is offline
I don't know.
My question is- the seller won't cover damage during shipping? Did you look into this? I hope it works out for you.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 12-14-2014, 03:31 PM
Default power booster Firebird swap rebuilding
Today i spent some time to open my old 77 Firebird power booster and a new damaged one where the black plastic leading for the pinionshaft was broken during transport to Germany.
I build an special tool to turn the old case open and i could see howe the booster is build inside ...easy to do!!!
The black broken plastic is easy to swap ...an clamp hold it into place and it`s easy to loose with an screw rider ...so you can remove the black plastic leading for the shaft ...i reused my old plastic shaft leading from my old booster ...
Amazing to see how bad the modern remake boosters are ..thin material ..not to compare with the old original GM booster cases ..the best way would be to buy a new booster ..open it and reuse your old booster case with putting in the new inside parts ...!!!
here`s some pics ..
hope i can somebody help with, because you find nothing about it in the world wide web !!
ID:	384439   Click image for larger version
ID:	384440   Click image for larger version
ID:	384441   Click image for larger version
ID:	384442   Click image for larger version
Old 12-14-2014, 03:33 PM
Default power brake booster Firebird
some more ...
ID:	384444   Click image for larger version
ID:	384445   Click image for larger version
ID:	384446   Click image for larger version
ID:	384447   Click image for larger version
Old 12-14-2014, 03:36 PM
Default 1977 Firebird power brake booster
and some more pics ...
ID:	384449   Click image for larger version
ID:	384450   Click image for larger version
ID:	384451   Click image for larger version
ID:	384452   Click image for larger version
