1965 GTO California car
I have a 65 GTO hardtop 4barrel 4-speed California car. Does anyone know what differences there were under the hood. I am trying to restore to original. At some point the radiator was replaced [not Harrison] so at the same time I believe the upper hose was replaced. For some reason the upper hose is V shaped and must of hit the snout of the air cleaner so they just cut a few inches off. Is the 4barrel base the same as any other car and did it use a different hose or T stat housing?
1965 GTO engine pics.
http://forums.maxperformanceinc.com/...attach/jpg.gif
http://forums.maxperformanceinc.com/...attach/jpg.gif http://forums.maxperformanceinc.com/...attach/jpg.gif This is what I have now. |
Hopefully someone who is better versed on California cars will chime in here, but I thought part of the GTO package was variable fan? The fan on your car looks like the one on a 326 Lemans engine. Also either a fan guard or the fan shroud is missing, whichever was applicable.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
1965 GTO
I think all 65 GTO 4 barrel cars had a pancake type round chrome air cleaner which had no snout, but I may be wrong.. Our host and other Pontiac parts suppliers have repros for sale, along with the correct hoses, clamps, etc. I am no help on what else might be applicable to a Califorina car as opposed to the other 49 state vehicles. I'm sure someone who owns one will chime in.
1961 Corvette 4spd. 1969 Chevy K5 Blazer - currently restoring |
Air cleaner seems to be correct
wrong Master cyl wrong alt BTW, Not all 1965's had rosette rivets on the VINs here is a video of a nice 1965 GTO in Cal it seems to missing the tube from the air cleaner to the valve cover...yours seems to have it this video might help you.....Post your DATA plate from the firewall that will help us to help you even more http://www.youtube.com/watch?feature...wjkIJVo#at=732 |
http://forums.maxperformanceinc.com/...attach/jpg.gif The video car has the air cleaner facing the wrong way, you can see where the vent tube is far back and would be in the correct spot to connect where the K&N breather is, I think they are trying to cover that up. Yes I know the master cylinder is wrong, the car sat in one spot for 26 years and it had to be replaced along with the biggest flat spots ever seen on bias ply tires. |
Your Fremont (BF) built 65 looks to be mostly correct under the hood. Must have been sold new in the state of California for it to have the 614 option (Positive Closed Circuit C/Case Ventilation System).
Unfortunately someone took a hacksaw to the OEM air cleaner snout. That is a one year, one model air cleaner so it will be difficult to find. The black painted vent tube to LH valve cover is correct. Also the sealed (not vented) chrome oil fill cap with the AC stamped in center is factory correct for the 614 option. Upper hose, radiator cap, fan, alternator, master cylinder and water temp sending unit? are what I see being incorrect. Can you post some pics of the exterior and interior (colors, options)? Below is an example of what you have (65 with OEM Calif. air cleaner, etc.) and also has the wrong upper flex hose.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
65 GTO
Would the 614 option be on the PHS anywhere? I wonder if the snout was used on any other cars, if I could find one, I could remove it and reattach it, looks to be just spot welded on. Working on more pic's, having upload failures. |
65 GTO more pics
http://forums.maxperformanceinc.com/...attach/jpg.gif http://forums.maxperformanceinc.com/...attach/jpg.gif |
Actually it seems someone cut the end of the snout off in the car that started this thread it should have a trumpet style end like the one in the video. It is facing the correct way and he does have the correct looking tube to the valve cover. |
not sure why my last post is showing up so late.....I see 60's stuff already covered it.
65 GTO
I THINK not 100% sure, ... but I think you have Quick steering 612 (?) AND 614 Cali Emissions together for code 616
65 GTO
So if anyone has a uncut CA. air cleaner could you please measure the length on the snout and width of the horn end. I may have better luck finding a new snout and spot welding it in place of this one. Also if anyone has a correct fan or Harrison 4 core let me know. Hopefully all upper radiator hoses were the same and the correct one will go around the air cleaner tip. If anyone has a pancake air cleaner and can tell if there correct upper hose would work around this air cleaner let me know.
612 + 614 = 616. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
It's a little easier to read (and gives a bit more detail) than the PHS IBM punchcard. There's a good chance it will still be there and be in good shape. K
65 GTO
The tank was replaced just before I bought the car, the owner thought they needed to get it running to sell so they replaced the tank and sending unit along with all new brakes and tune up and tires. I did see the tires they were bad but I should of kept them, they had good tread and were dated from 1970. So I have manual steering how would I check for quick steering, is it less lock to lock turns?
