Qjet info
Can anyone tell me what this carb came with originally for jets and rods? Here is the number: 17058241
When I got this carb the jets and rods were missing. Also, what are the correct sizes for the idle/main air bleeds, down channel restriction, etc. Thanks!
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
It cam off of a 78 Pontiac 350 auto , sorry but anything more than I con not be of help but Cliff and others most likely can!
1978 Buick carb, and a good one. Those carbs don't need much help, I know all the details and can help set it up for any application. Contact the shop when you are ready, I stock everything for it......Cliff
