Hey all.
Forgive me if this has been covered elsewhere, I did try a search but came up empty handed. Simple question really, Is the '67 Chevelle Package tray steel the same as/interchangeable with a '67 Tempest Mine has rotted out, and I have 2 options, one just fab a new one, or be lazy and buy the chevele one and modify to fit. I noticed the one that is available comes with a deck lid support too, and certainly thats missing from my car. All help much appreciated Col |
The Chevelle piece is shorter but it may be possible to make it work. I'm surprised that no one has restamped the lower support for BOP
![]() Quote:
Col |
its not close enough, i tried it years ago..ya have to buy a used one
lemans skylark and cutlass interchange
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." ![]() |
If I had a good clean used one, i could get them stamped out. Not sure why it hasn't been done already. They always seem to rust out.
Hmm. not so good then. not right in any dimension? Used ones seem like hens teeth to find, but not impossible I guess
width is right..
the BOP cars are about 5 inches longer from the inside edge of the package tray to the edge of the decklid...so both are longer to make it up..its a lot of work to put one in let alone butcher up a chevelle one just because its avail...rust frees arent hard to get...you just gotta buck up and spend the money
![]() Quote:
I shall continue the hunt, but for sure theres nothing over here in the UK! |
Col, do you mean you're looking to replace the package tray steel just behind the rear seat, or the deck between the rear window and the trunk lid? You're getting two different replies. I think you're asking about the one inside the car behind the rear seat to the rear window.... correct?
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
![]() Quote:
Mine is toast and the support under the section from the window to trunk lid is non existent too! That's the reason I was asking about the chevelle one as it comes as a whole unit with that under deck support, so if I need to extend that but 5 inches should be simple enough . Col |
We're looking to repro that piece, along with the 67 quarters, trunk pan, and other ancillary pieces just as soon as we can find a good car to use as patterns. Willing to pay and travel for the right car. Good quarters, trunk floor, etc.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
Jerry- I have seen many good donors. However they are all out west. Might have to buy a complete car and strip it down. More expensive for sure, but in the grand scheme of reproduction, I don't think it will make a bit of difference in the final cost
Col, if you have a body shop near by that works on restorations ask them if the one from a Chevelle will work. If they've worked on either either body before they might know. Or take measurements and compare the two if you can, but still ask them.
![]() Quote:
Waiting on a couple of prices from breaker cars, just looking at all the options |
Look on the Year One site and see if Chevelle and GTO use the same part number for the package tray interior panel. If so, the metal is the same dimensions on both cars.
Good idea, checked, and yep they have the same part number. Looks like will need to mod the support panel but the rest should be ok
Check with Dynacorn.com. http://www.dynacornclassicbodies.com/classic2.html
Contact them and ask if you can buy the package tray shelf separately from the body. Maybe they'll do a special arrangement for you seeing you're in the UK. Won't hurt to ask. Worst case is no.
![]() Quote:
If you run across anything, please let me know! Of course I'll pay a ff if we make a deal.
