Rear oil galley plug
Guys what size is the infamous plug....
I want to pull it and change it out to a softer one so I can drill it .030.... Unless someone has one drilled already.......Thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Oil Gallery Plug will be case hardened. Easy to heat the plug up to cherry red (after it is removed from the block) and then let it cool and drill it to size: .030"-.040" for lubing the distributor gear.
I hope the engine is on a stand. But if the block is on the ground that will work too. Sometimes the plugs need a lot of "leverage" to remove them. Plug is an odd ball size that takes a Male 5/16" square head drive (if memory serves me right) to fit into the plug. Tom V.
Yup, 5/16" square!
If you have a long round head punch who's tip will fit in the square then beat on it and you will jar the threads loose and then be able to back the plug out.
thanks for the tips guys
BTW, it's a 3/8" pipe plug. I drill them by spinning a .030" drill bit real fast in a drill press. Then, holding the plug in my fingers, with both hands, I slowly feed the plug up into the drill bit until it goes through. Start drilling from inside the Allen wrench hole so the burr when the drill bit comes through will be on the flat, back side of the plug for easy de-burring. I have never broken a drill bit drilling them this way. If you feed the drill bit down into the plug, you will most certainly break the drill bit.
Thanks Paul....
Another way to go is to cut a slot with a hack saw on the thread side of the original plug but not all the way to the edge, then just use the drill bit to go thru the last.060" of plug.
Chris, if it's the engine you've rebuilt a couple of times, the factory plug should be long gone. If so, the plug in there should require an allen head for removal.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
I guess I should have stated that my bad
Snap on males a special socket that fits the 5/16 square, Chris may not need it, but...
They also make a set of all those oddball squares, male and female...
A long 1/2 drive extension works good for popping out the rear freeze plug to get to it on an assembled short block too.
If it's a hex drive, it's a 5/16" or 8mm also works.
I considered the cost of the hex plug plus my time to drill them. Pontiac Dude has these available for a couple of bucks each. I bought a handful from him last time I ordered something. It was an easy decision to make
That is the way to do it. Butler Performance also sells them..
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
