Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-16-2014, 11:52 AM
Donovan Donovan is offline
Default FS - Ported 1968 #17 heads
$600 plus shipping
A pair of 1968 350 heads. Originally #17 two barrel. They were cleaned, smoothed casting flash out and crack checked. Then ported using the guidance of Jim Hand from his book and the McCarthy video. A performance multi-angle valve job was done and later the valves were back cut. Pushrod bulge laid back, no tubes. The heads were cut 0.030 to reduce the chambers some, the chamber walls were laid back on the intake side for flow. Finally chamber cc is about 80cc. The stock valves and valve size were retained 1.96 intake and 1.66 exhaust. Springs are Comp cams 995 shimmed properly and good to 0.500" lift flat tappet or hydraulic roller. Rocker studs were converted to screw in studs and have the factory style non-adjustable studs installed. I will include a set of BBC studs for adjustable valve train. Rebuilt and have not been run. I've got $700 in parts and machine shop labor on these heads.
-Stock 1.96 intake valves and 1.66" exhaust valves
-Back cut on both the intake and exhaust valves
-Intake port openings are standard at 2.08 x 1.12"
-Pushrod holes elongated for 1.65 rockers
-Crossovers are aluminum filled (piston aluminum)
-Stock guide plates
-Performance 5 angle valve job with stock 30 degree seat
-seat is 87% of the intake diameter @ 1.7" (intake)
-stock guides were checked and found in spec
-7/16" rocker studs included as well as Stock bottle neck studs
-995 Comp springs
-Machined guides for retainer clearance and seals
-New positive performance seals installed
Compression would look like this (assume 0.030 over bore on all, zero deck and 0.041 gasket, 6.7cc dish)-
455 = 10.9 to 1
428 = 10.3
400 = 9.7
389 = 9.5
383 = 9.3
350 = 8.8 (9.4 with common flat tops)
326 = 8.2
Here are the flow numbers @ 28"
LIFT - Intake / Exhaust
.100 - 76 42
.200 - 147 90
.300 - 198 122
.400 - 224 144
.500 - 242 160
.600 - 244 167
(these numbers were recorded without putty or a pipe and before I back cut the valves)
In the past I posted in topics on the board about the heads, here are the links-
Crossover fill- http://forums.maxperformanceinc.com/...93&postcount=5
General detail and discussion - http://forums.maxperformanceinc.com/...ghlight=ported
ID:	370266   Click image for larger version
ID:	370267   Click image for larger version
Old 07-16-2014, 11:57 AM
Default More pics of the heads
1968 #17 350 heads
ID:	370275   Click image for larger version
ID:	370276   Click image for larger version
ID:	370277   Click image for larger version
ID:	370278   Click image for larger version
Old 08-23-2014, 10:44 AM
Also looking for trades.
68-69 manual console, Firebird
4150 Carburetor, 850cfm
4150 style throttle body for fuel injection
M21
Other manual transmission swap parts
8.2 saf-t-track 3.23 carrier (maybe other ratios carrier with gears)
Old 09-01-2014, 02:38 PM
Notes-
Pulled a center exhaust valve-
Valve length = 5.015"
Measured outside exhaust port and valve spring installed height-
Exhaust port volume is 175cc
Spring install height is 1.59"
measured 2 intake ports -
170cc intake port volume
Old 09-02-2014, 11:52 PM
Default More detail in the ports and under the valves
some pics of the head with valves removed
Shipping will be about $80 total in the states.
ID:	375175   Click image for larger version
ID:	375176   Click image for larger version
ID:	375177   Click image for larger version
Old 06-08-2015, 08:57 PM
bump^
$550 shipped or trades
