I suspect, like many of you, when I was restoring my 1974 SD I decided to install the faster ratio steering gear internals into my original box (seemed like a good thing to do). Overall I'm happy with it however I did notice that the turn signal more often than not wouldn't cancel after making a turn. I assume this is due to the faster steering box (2/1/2 turns lock to lock rather than 3 1/2). Anyone else experience this and did you come up with a solution? I've looked around for cancel cams from a later TA but they don't seem to be that widely available anymore. Suggestions appreciated.
Dick Winkles 1970 RAIV GTO 4-speed 1974 Original owner Z-28 4-speed 2008 SRT10 Viper Very Orange (was SD TA!) 2015 Challenger Hellcat 6spd (was SD TA!) |
Are you sure the cancel springs aren't broken, or messed up. The faster steering in my opinion should not make a difference. On mine if I turn a turn signal on, I only have to move the steering wheel barely a 1/4-1/2 turn and back and the signal cancels. So the fact that you lost a full turn over all I can't see that making a difference.
Maybe someone else knows for sure and will prove me wrong. ![]()
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
As pepi says,your problem is likely in the column...broken cancelling springs are a common issue...
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
/\ /\ /\ What they said!
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
