Later thinking about smaller Distrib.
Maybe just maybe after Norwalk or i hit the lottery, thinking about changing to a smaller
DIA. & all HEI set-up Maybe-, Question i want to drop in a Billet distrib. no extra modules no extra anything, drop it in in place of the big HEI and be done with it!! period!! Anything out there i can even use my new HEI wires on???? |
Best thing I did was getting RID of that module! I like the MSD box and billet dizzy. EASY to wire plug and play!
461 Stroker: 265/276 Comp Cam Solid roller . 340CFM E-Head Victor Intake 1050 Dom Carb. 390/430 9" Gears with a T400 trans 4200 converter. Street weight 3850. 1.49 60ft. 275/60/15 M/T DR 10.57 SO FAR |
Subscribed
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." Thomas Jefferson |
400 plus,, Billet Dizzy???? explain????
I have the MSD 8563 billet dizzy with no vac adv. I like the ease of it. Easy to adjust or lock out. Box im using MSD Digital 6 PLUS
Have an Accell Street Billet Distributor on Debs car(69'bird with 406) Rich. Same size as a non HEI Delco but has a HEI type module and mag pickup inside... Cap uses HEI ends but a std terminal cap can be used. Worked fine with a standard 12 volt Delco coil. Has adjustable vacuum advance and comes with springs to tune mechanical advance.
Presently the module is bypassed and run an Accell 300 CD box that has rev limiter and multi spark plus the matching coil. (Better cold start with no choke and better cold idle only noticeable difference over running module and std coil) Module looks and wires same as an HEI module... I left it in for backup if cd box fails and keep a std coil handy if goin out of town. 10 years now with no problems including drive from upstate NY to mid TN (@1000 miles) on a very hot July day with temps in shade pushin 100 degrees and caught in construction traffic numerous times and even a downpour. Lots of miles elsewhere. We are pretty satisfied. Its an easy install. |
Rich as I said in the other post This is a photo of my yes (race) Pertronix flame thrower Hei dist NO vacuum advance in the dist. It's locked out please check out summitracing for parts Proform 67022c $12.97 or Davis unified ing 333333 $9.97 cheap and simple .
Other side. It will let you run your coolent lines
BUY THE PRIUS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NO DISTRIBUTOR TO WORRY ABOUT!!!!!!!!!!! JK
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
prius
I also suggest the prius. The only thing dizzy needing an explanation then would be the driver!!!LOL
We need a "Like" button.
