Old 05-11-2014, 03:26 PM
1965 Pontiac Parisienne's Avatar
1965 Pontiac Parisienne 1965 Pontiac Parisienne is offline
Default 1965 TH 400 kick down switch into trans
HI,
i have a leak at kick down switch connector goes into the case ..
How can i replace only the O ring ?
Have i to remove the oil pan or can i do it from outside ?
Some pics of the part what i mean.
Thx for any help,
Cheers, Bjoern
Name:	kick down gasket.JPG
ID:	363135   Click image for larger version
Name:	kick down switch.jpg
ID:	363136   Click image for larger version
Name:	kick down switch 1.JPG
ID:	363137   Click image for larger version
Name:	kick down switch 2.JPG
1965 Bonneville 2 door coupe nightwatch blue AZ car
1965 Bonneville convertible starlight black
1966 Star Chief Coupé
1965 canandian Parisienne custome sport convertible AZ car. „Sold“
1977 california Firebird Esprit [/SIZE][/FONT]
Old 05-21-2014, 06:45 PM
65WJ's Avatar
65WJ 65WJ is offline
transmission pan yes. iirc you will be able to see clearly once the pan is off
patrick
Old 05-21-2014, 08:11 PM
stevep's Avatar
stevep stevep is offline
The correct way is to remove the pan. I have removed the connector with vice grips without dropping the pan, but it doesn't always work.
