I have up for sale the old cast iron intake and Rochester Q-jet carb from my old motor.
I'll start with the intake. The intake is a Pontiac cast iron and it comes with the intake bolts. The numbers from the intake are as follows: 9794234 along one of the runners and the date code reads D118 which I am assuming makes it a 1968. The intake is in excellent shape and has everything still on it just as I pulled it from my motor. I'd clean it up, shoot it with fresh paint, and bolt it on. The carb is a 1969 Rochester Quadrajet for Pontiacs. At least that's what I decoded from the numbers on the carb body. I used Cliff's website to ID this carb and it says that this is a 1969 Pontiac Quadrajet carb from a automatic trans car. Here are the numbers from the carb body: 7029268 and then there are other numbers that read 0141....I couldn't decode them. This intake and carb came off of the 1968 400 that was in my 68 Firebird. I have since replaced that motor with a rebuilt 1969 428 and I no longer need some of this stuff. This carb ran fine on my car when it was pulled. Obviously you could rebuild it if that suits you but it came off of a running driving car. I'm asking $250.00 shipped for both the intake and carb and I'm even throwing in the factory throttle cable bracket. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Greg 68 Firebird Verdoro Green 428, 6X-4 heads, Comp XE284 cam Muncie 4 speed 3:73 rear |
call mark 3344260372 thanks
Would you be interested in splitting them up?
Interested in carb. |
