SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
F/S Various Pontiac Performance 400 parts
All of these engine parts were pulled off my Pontaic 400 with less than 2k miles on the engine. All prices are without shipping added. I will only accept Paypal for payment. I can get you a shipping quote for anything as long as you send me your zip code.
First up COMP Cams Magnum Pushrods 7263-16. Rather than list all the specs here I'll just link to Summits Web Page. They list for $100 I'll take $50 Pushrod Specs Next Up a set of blue Taylor P/N 73653 Spiro-Pro 8mm Spark Plug Wires with spark plug wire brackets. They list for $65 without the Brackets I'll take $40.00 Next is a Professional Products Hurricane Intake Manifold P/N 56031. Comes with the carb adapter and four carb studs. Also has a thermostat with housing although this intake has been sitting for a couple years so I'd recommend replacing the thermostat. Summit lists it for $250. I'll take $175 Next up is a set of ARP High Performance Series Cylinder Head Bolts Kit P/N 190-3605 I'll just list the summit product page HERE Summit lists them for $83 I'll take $40 Next up is an ARP 2 bolt Main Stud Kit P/N 194-5401 Summit lists the kit for $84 I'll take $40 Next is a Roll Master timing chain. Butlers has them listed at $80 I'll take $40 Next is a Pioneer SFI Balancer P/N 872031. More info can be found at Summit Racing HERE. It does have some black engine paint on the front and some corrosion along one side of it. Comes with a crank bolt. Summit lists it at $170 I'll take $85 Next is a Mr. Gasket chrome plated fuel pump. P/N 7710. Asking $25 Next I've got a few stock parts laying around. Prices on these do not include Oil Pan $25 Chrome Valve Covers (slight rust but can prob be cleaned up) $15 Timing Cover with water pump $25 (condition of the waterpump is unknown but it did work when the engine was together) I'll also take $50for all three if you buy them together. |
PM sent on oil pan.
PM sent on balancer
Is that a aluminum pump on that cover??? If so ill take em plus the timing chain.
*edit* PM Sent Last edited by n0b0dy1987; 05-03-2014 at 07:53 PM. |
Balancer is SOLD!
All PMs replied to.
Ill take the stud kit I pmd you thanks Scott
pm sent
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
I'll take the spark plug wires. Sending pm.
All PMs replied to.
Spark Plug Wires and Head Bolts are SOLD! Main Studs, Timing Cover and Chain, are sold pending payment.
Payment sent for the main studs thanks Matt Scott
Second on the timing cover/ pump if the sale falls through. Thank you!
Sammy 1967 Lemans: 455 swap in progress (stock crank, stock rods, TRW slugs, mildly ported 6x heads, Stump Puller hyd roller, 1.5 PRW aluminum rollers, Comp hyd roller lifters, Performer RPM, q-jet, RA exhaust manifolds, 2 1/2" exhaust, ebay HEI), 200 4R, and some suspension stuff |
all 3
If it gets to me i'll buy the water pump/timing cover and valve covers package
Main Studs Sold.
PM sent on the fuel pump
I shipped out numerous items today. Headed to work now will PM all of you who made payments your tracking numbers when I get home from work.
Everything but the Push Rods and Intake Manifold are SOLD!
New Prices on the last two items to try and push them out the door. Push Rods $25 Plus Shipping! Intake Manifold $150 Plush Shipping! |
