66 OHC six from a tempest custom
Its seized and missing parts, loooking to get rid of it for cheap
It also has an air cooled powerglide attached to it
Where are you located?
I'm guessing its a one barrel motor which will not fetch much money. The parts on it will sell better if bundled so removing them and putting them in groups will be a benefit to you and the buyers. Depending upon the year I am looking for a good oil pan. Also see if you have some wire harness clips and a double alternator pulley. The accessory drive with a good alternator has value as well as double pulleys. If it is a Sprint there re a ton of goodies on it. Although they don't sell fast there is always someone looking for a set of head bolts or exhaust bolts. If its coming from a Tempest does it have the seven bladed fan?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Im in billerica mass, ill look at the motot tonight
Here it is
Parts or whole?
The bolt on parts are where the $ is. The Long block & trans not so much. I'd be interested in the complete Timing Belt Cover & PS bracket if you decide to sell parts. LMK Thanks
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Ill part it out, to be honest I was gonna scrap the thing but an old timer I know said that they were worth some money
PM sent
