Old 04-14-2014, 05:45 PM
slowbird's Avatar
slowbird slowbird is offline
Default 16v batteries?
I am in need of a new 16v battery. Anyone have any opinions? I am looking at the XS Power 16v battery.
Old 04-14-2014, 05:55 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
they are heavy as conventional batterys.
Old 04-14-2014, 08:15 PM
Probird's Avatar
Probird Probird is offline
That's what I bought at the beginning of last season Brian. It did a great job and is going strong. I bought it as a kit with the charger.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 04-14-2014, 08:24 PM
aaronman aaronman is offline
X2 what Probird said. I have 2 XS Power batteries and 2 chargers. No issues in 2 years.
Old 04-14-2014, 09:30 PM
mike leech's Avatar
mike leech mike leech is offline
they do rock!
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 04-14-2014, 10:24 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I run a Powercell and it has been a great battery the past 3 years, and only weighs 9#s.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
Old 04-14-2014, 10:45 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Jack
Do you run an alternator? Im thinking of switching over to those but I need to run a big alternator while running down the street. I havent seen many small batteries on drag week. Was concerned about heating the battery up.
Old 04-14-2014, 11:35 PM
mike leech's Avatar
Originally Posted by jdw_poncho View Post
Jack
I know you asked jack but they are not alternator friendly because they discharge at a constant voltage.
EHTTFMF!
Old 08-28-2019, 06:42 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Reviving this old thread. I’m looking into upgrading to a 16v AGM battery, wondered what brand you guys are using successfully. I see people are fond of XS and Rock... guess one’s as good as the other?
After brand, is there a particular “model” you prefer?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 08-28-2019, 07:01 PM
mysticmissle's Avatar
I like my turbo start. Heavy but hasn’t let me down also run and alt but many do not
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 08-28-2019, 08:39 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
I hear the XS D1600 I the one to have. I have a friend of mine who runs a pair of them and a alternator. Double entered his s-10(small block 12:1 motor) and went 14 rounds to win pro and super pro the same night.
But I am hearing good and bad reviews on the 16volt systems.
My biggest hold up on going to them is I hear a 16v battery doesn't start to go bad it will just go dead on you out of nowhere.
I have been bit 3 times by the not enough voltage bug this year. Im interested in hearing other stories.
Fwiw I warranted my 2red tops and they switched them over to yellow tops at no extra charge. I recently added a alternator and ran a 6 gauge wire to the battery side of the on/off switch. Cross my fingers and here we go down the stretch to make another run at a championship!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.854@160.12 in Brainerd MN 7/2024
Old 08-28-2019, 09:56 PM
Elarson's Avatar
Elarson Elarson is offline
We used XS Power in the Grocery Getter and had zero problems.
Eric
Old 08-29-2019, 02:19 AM
thadeal4real thadeal4real is offline
Haven’t been on in 4ever holy thread revival
"The democracy will cease to exist
when you take away from those who are willing to work
and give to those who would not."
Thomas Jefferson
Old 08-29-2019, 01:32 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Nobody is running away with it. You're looking good, just need them boys to lose a few and you to get a few rounds. Get after it!
Dave Polichena
Old 08-30-2019, 06:32 PM
cgeise's Avatar
cgeise cgeise is offline
XS has two diff 16 volt battery's one is 48 lb the other like 34 lb - I run the lighter on with a 105 amp 16 volt alt, I need the alt because of the high amp draw with the FI I am running now -- if you go this way you need a voltage reducer for your fan IT WILL NOT LIVE at 18 plus volts an alternator puts out . my son runs a 9 lb 16 volt from Altonics and has had good luck, I asked about running with an alternator and they said it would be ok ??
Old 08-30-2019, 09:11 PM
Go get em Jason! Hope all is well!
Old 08-30-2019, 10:37 PM
S/st 54's Avatar
THANKS! I missed seeing ya up in Brainerd,But I saw you were at the dyno checking out the power plant for your whip!
Curt,the voltage reducer is my biggest hold back on going to the 16v system.
Are there any other accessories that won't live up to a 16v(18v with alternator)
System?
IMO 16volt is the way to go. It's an invesent for sure. However, I just don't know enough about it to really feel good about pulling the trigger.
Old 09-01-2019, 12:29 AM
Considering going this route. May add voltage step-down later for lighting.
XS XP1000 battery, with 16v “Intellicharger”
XP1000 = 2400 max amp, 675 cranking amp
https://www.summitracing.com/parts/xsp-xp1000ck2/
Matt
70 GTO 400 4-speed
Old 09-01-2019, 01:16 PM
cgeise's Avatar
the fan is the only thing I had issues with for a charger I got the charger that will put out 50 amp -- it recharges real fast --
Old 09-01-2019, 01:21 PM
S/st 54's Avatar
Which charger is that?
Do you have a link and or part number?
