Old 03-27-2014, 06:13 PM
GConner's Avatar
GConner GConner is offline
Default Gasoline in crankcase oil
At my last oil change I had an oil analysis done. It showed gas in the oil. Where are the places I should look for the infiltration? Could it be coming from the mechanical gas pump? I have no gas or oil leaks on the outside of the engine.
Old 03-28-2014, 07:00 AM
Txbobcat Txbobcat is offline
Normally that means the fuel pump has an internal leak. Change it out and change the oil and filter again
Old 03-28-2014, 07:05 AM
steve25 steve25 is offline
could also be from running too rich, wipe your finger in the tail pipe, do you get a black non oily film on your finger tip?
Does your fuel milage really suck?
Is the motor hard to restart when fully warmed up?
Old 03-28-2014, 10:19 AM
Birdguy's Avatar
Birdguy Birdguy is offline
I would check compression on all cylinders. Worn rings can allow fuel bypass on the compression stroke, especially if it's running too rich.
