#81
Old 03-28-2014, 02:39 PM
mike leech's Avatar
mike leech mike leech is offline
After much more crying Leech said:
You are truly delusional.
I'm sure you think anyone not milking cows is delusional. So smarty pants you tell me how much does a state of the art ex coughlin prostock weigh complete with titanium hardware (nuts and bolts everywhere) carbon fiber body, carbon fiber brakes etc. You highlighting what a moron you are. I've seen the car. Its triple throw down bad. and light. get the weight. cause it matters.
Originally Posted by Stan Weiss View Post
Using 1128 Dynoed HP, 2000 lbs, 5 speed trans, and 2700 DA
60 Foot ET = 1.2078
330 Foot ET = 3.1286
1/8 Mile ET = 4.6850
1/8 Mile MPH = 158.9112
1000 Foot ET = 6.0299
1/4 Mile ET = 7.1660
1/4 Mile MPH = 199.0816
Using 1177 Dynoed HP, 2100 lbs, 5 speed trans, and 2700 DA
60 Foot ET = 1.2078
330 Foot ET = 3.1296
1/8 Mile ET = 4.6876
1/8 Mile MPH = 158.7797
1000 Foot ET = 6.0331
1/4 Mile ET = 7.1689
1/4 Mile MPH = 199.1982
Using 1226 Dynoed HP, 2200 lbs, 5 speed trans, and 2700 DA
60 Foot ET = 1.2078
330 Foot ET = 3.1299
1/8 Mile ET = 4.6891
1/8 Mile MPH = 158.7339
1000 Foot ET = 6.0344
1/4 Mile ET = 7.1694
1/4 Mile MPH = 199.4059
Stan
Thank you Stan. here we can easily see why everyone would like to know the weight....200lbs = 100 hp in you sims. sounds right. johns site is 100 hp less though... I thought calculators were all accurate? guess not.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #82
Old 03-28-2014, 03:09 PM
Not only delusional, but not very bright?
He is using the weather corrected numbers.
If you use the weather adjusted ET and try it, it would probably be closer.
(that one you used is for STP)
Stan's calculations are also much more elaborate, so would be more accurate.
Mine is for a ball-park figure.
(and for quick use)
  #83
Old 03-28-2014, 03:55 PM
mike leech's Avatar
(and for quick use)
Ha! a more elaborate guess! we still have no weight!
my god you're a a real gem
EHTTFMF!
  #84
Old 03-28-2014, 04:34 PM
GTOGEORGE's Avatar
I think Stan's numbers look pretty damn GOOD to me!
GTO George
  #85
Old 03-28-2014, 05:42 PM
3fastgtos 3fastgtos is offline
KRE's MR-1 THE BEST Aftermarket Pontiac Block Bar NONE!
Hey, I still want to know why you believe this. I've asked several times, if I missed the answer I apologize in advance.
SD
  #86
Old 03-28-2014, 06:08 PM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
SD
I was kinda curious about that myself!
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
  #87
Old 03-28-2014, 06:54 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Originally Posted by mike leech View Post
......So smarty pants ........
Now,that's just over the line.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #88
Old 03-28-2014, 10:52 PM
mjm421's Avatar
mjm421 mjm421 is offline
How much ballast can a pro stocker legally add?
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
  #89
Old 03-28-2014, 11:07 PM
Probird's Avatar
Probird Probird is offline
If I read it right, anything faster than 8.49 is 250 lbs.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
  #90
Old 03-29-2014, 10:35 AM
That's probably ET racing.
Here's the Pro Stock from rulebook:
  #91
Old 03-29-2014, 10:50 AM
mjm421's Avatar
Back to topic. As much as I like to try and antagonize Jack (all in fun) my prediction is: A LOT of horsepower and very fast! 1113 hp.
  #92
Old 03-29-2014, 11:04 AM
Stan Weiss's Avatar
Mike,
So all of these calculator are just guesses. So please do explain how from et, mph, and weight you can get a HP number that is anything other than a WAG?
Stan
Pontiac Pump Gas List
  #93
Old 03-29-2014, 12:37 PM
mike leech's Avatar
Mike,
Stan
you sir are guessing at the weight of the kre car. if you know something other than a gues speak up. It's NOT 2300 lbs. Get the weight then we can have a useful talk......but most of them go in the useless direction and i will not continue a back and forth about bs.
and by the way a wag is all that is possible with missing info. get the weight and we can move on to a swag.
If we have weight, et, and hp we can remove one and reasonably calculate its value. We were trying to figure out how much the kre boys are making with a warp 6 535. WE CANNOT FIGURE THAT WITH ONLY ONE KNOWN DATA POINT! Please i'm trying to be nice here but dang it you're doing this on purpose. No where did jack say he would make 1300. You did. Don't think for a minute that what you are really doing is not obvious. Some ill planned form of race head "Social Justice"
Lets set the bar "for" jack so high it unreasonable then call him a failure for not getting there, EVEN IF HE BUILDS A STOUT COMBO THAT IS IMPRESSIVE. You guys and your retarded nonsense is laughable. I'm sure you see it as retribution for him being mean to another head. The difference is they made the claims not him. And there are still no takers on that front that can come even close to the same performance as even the ehead let alone tigers, and kre high ports.
cheers
EHTTFMF!
  #94
Old 03-29-2014, 01:52 PM
Probird's Avatar
I read that and it looks like it tells you how much the max is in certain spots on the chassis. It really doesn't give a max there. It refers you to the general rules where it says max is 250 if under 8.50. I don't know....it's a little confusing.
  #95
Old 03-29-2014, 02:07 PM
Probird's Avatar
Hard to say what KRE's car weighs. I know my chassis car weighs 1500. Although it isn't finished, it's a rolling chassis with a heavy Dana 60 rearend and is mild steel not chromoly. I weighed it with a powerglide case, 428 block with iron heads, headers. Basically it's missing wiring, a rotating assembly and about 85lbs worth of transmission internals. The iron heads make up for some of that compared to aluminum heads. I think finished it will come in around 2100 lbs maybe less since I have to put a new chassis under it and it will be chromoly.
  #96
Old 03-29-2014, 02:26 PM
mike leech's Avatar
Nice! I had no idea rick! Start a tread on that bad boy! hope that goes well on the rest of the build.
Clearly a state of the art pro stock all chrome moly cage with a carbon fiber body and carbon fiber interior with titanium hardware would be significantly lighter. Not to mention a small driver.
EHTTFMF!
  #97
Old 03-29-2014, 02:28 PM
Stan Weiss's Avatar
cheers
Mike,
The only person locked into 2300 lbs is you. I have posted HP numbers based on 2000 lb. (your estimate of its eight), 2100 lbs, and 2200 lbs.
I along with Aaron believe that Lil Jack's engine should be able to make 1300 N/A HP. When reminded that Nitrous engines are not all-out engines like N/A engines I did post a revised N/A HP number. In a all-out 400 ci engine with a smaller bore (ie smaller intake valve) spacing Visner has made around 1180 HP. I know 120 HP more from 141 ci is asking allot.
When all else fails, you go back to the same old cylinder head BS. I do not know if it is lack of reading comprehension, or bad memory on your part, or just wanting to be argumentative. One more time. I have no cylinder preference
Stan
What cylinder head is this?
  #98
Old 03-29-2014, 03:00 PM
mike leech's Avatar
Stan Stan Stan. I said 2000 ish. Comparing jacks to An Existing and continually refined pro stock effort only further highlights your bias and inexperience. Have you or Arron(no disrespect to him) ever built a 1300,1100, or 1000 hp NA anything? While you're discussing how easy it is?
And ps. How many more times are you going to post that picture of an engine you had little to do with? Could you please just count how many more times you want to and just make one final post with that many pictures in it?
EHTTFMF!
  #99
Old 03-29-2014, 03:26 PM
Tiger Paw Tiger Paw is offline
I gotta get to Norwalk this year!
  #100
Old 03-29-2014, 03:44 PM
Stan Weiss's Avatar
Mike,
I do not understand Leecheese. How much different is "2000 ish" than 2000.
Maybe I am the one not has the Reading Comprehensive problem. But I am sure I saw Lil Jack talking about how he had the "A Team" building his engine not Stan Weiss. The only one using the word easy is you.
Again lack of comprehension on your part. It is not about who built the engine, but cylinder preferences. I will post that picture as many times as it takes for you to comprehend. Which means I will be posting that picture a lot.
Stan
Thread Tools
Display Modes
