New BOP One-Piece Rear Main Seal
New Product:
Viton® One-Piece Rear Main Seal The new BOP Engineering one-piece rear mail seal is the most advanced rear main seal on the market for the traditional Pontiac V-8. This revolutionary design features a number of state of the art innovations including relocation of the parting line which greatly reducing the risk of leakage. The seal is simply sliced at a premarked location and slipped around the crankshaft. A more pliable construction works more effectively in engines with seal groove geometry issues, and double lip design to provide twice the protection against leakage as well as supporting outstanding vacuum numbers. Recent testing pulled 22 inches of vacuum when silicone from around the valley pan failed. Visit our website for complete installation instructions. O RMS18 3.00-inch Main One-Piece Rear Main Seal $49.99 O RMS19 3.25-inch Main One-Piece Rear Main Seal $49.99 (coming soon)
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
I'm a rope guy but I might try it. I would like to take a look at the install instructions. Could they be posted? Or a link.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 03-18-2014 at 05:25 PM. |
Nice!!! can,t wait to try one out!!!
So you have to cut it to install it?
If so, why is it not sold precut? |
rear main seals
Are these any different then Butlers Performance Rear Main Seals ?????????
Part # Description Price BOP-RMS-01 Pontiac 3" Main Rear Main Seal made from Viton® (326-400) $38.95 BOP-RMS-02 Pontiac 3.25" Rear Main Seal made from Viton® (421-455) $38.95 http://www.butlerperformance.com/pro...ain_seals.html |
This is good news and seems like a forward step.
___________________________________ "Objects in mirror are closer than they appear" |
Wade...that is some down-home Wisconsin ingenuity! Nice work. If have to pull my motor for a rear main issue (mine only leaks a small drop), I will put one in and give it a try.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
Just got my engine completely assembled with the 2-piece viton and now this comes out; ahhhh! Lol
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
I still dont leak from my viton seal i got from you 3 years ago. If it does ever leak ill be buying one
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
I like it!
Nice! Great idea and product. Will be trying one for sure.
Wade, might be a good idea to make a you tube video to show the construction and an installation of the seal.
Sent from my SCH-R970 using Tapatalk
X2 on the youtube video it will let people out side this forum no about the new seal
Now lets get one made for the 3.000 mains!!
O RMS18 3.00-inch Main One-Piece Rear Main Seal $49.99 to the original post, this is great news.
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
My rope rear main seal is also dry but this may be worth a try in the future.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
Thanks Captain for that info.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
Sounds like a huge step forward. Time will tell. Hope to see positive feedback.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
