who sells heat wrap for brake lines??
New headers installed and brake lines on my 67 gto are right up against the header tube on each side. Anybody make heat wrap for the brake lines???
not sure if there is anything specific for brake lines but im sure the thinner wraps for wires etc can be used. & the brake lines usually have some play to allow to bend them away from the header, at least the 2nd gen firebird ones do. i had the same issue with the big 2" hooker super comps on my 72.
I use this DEI product to help shield fuel lines, etc.
http://www.summitracing.com/parts/dei-010403/overview/ You still want to be sure there is an air gap between it and the header, do direct contact... |
Aircraft spruce and specialty sell orange flexible shielding , fire proof
Why not play it safe and move the line?
I had this issue on my 67 GTO, some slight bending moved the line far enough away from the header to relieve me from any worries.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
