Old 02-02-2014, 03:17 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default MSD Style Box - When is it effective?
Does anyone have any dyno data or other real world experience that shows when an MSD style box truly becomes effective? I don't really need a fancy rev limiter.
Would a low compression 455 with a RA 4 cam see any benefit? Just wondering when does it start to show results? Always does? High compression? Big cam? High RPM? It seems like there are a lot of people running these with all different types of combinations but when does it really show some type of benefit?
Do we just put them on by default because everyone else has one so it must do something? I know that the high end boxes have additional features that benefit racers in a bunch of ways like timing control, etc. But for the 350 to 550 HP crowd is there any improvements to be had with the simpler bolt on boxes?
Thanks - Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 02-02-2014, 03:33 PM
Tom Vaught's Avatar
Boost Engineer
Personal Opinion, but based on info from our Research Ignition Expert:
A)
1) Benefits with Multi-strike pulses. Apparently more so with emissions + F.E. vs performance.
2) Benefits with higher amp ignitions.
3) Benefits with short Pigtail (plug wire) "coil on plug" ignition systems.
So the multi-strike pulse deal in #1 would be available on a MSD obviously.
Higher amp ignitions could apply to several ignitions including factory stuff.
Coil on Plug mostly on factory stuff.
B) REV LIMIT / OVER-REV PROTECTION.
1) Worth its weight in any discussion. Chit does happen and if a rev limiter will protect the engine, it is a good thing, even if you feel you do not need it.
2) If the spark fires when it is supposed to then 99.99999% of the time a second spark does nothing on a normal mild street car that an enthusiast would own.
3) Boosted Engine much more likely not to have the plug fire so higher energy and milti-strike is a big advantage on a street car.
JMO
Tom Vaught
Old 02-02-2014, 03:52 PM
Default Thanks
Tom,
Thanks for posting. Great info and insight. But just to clarify my comment, it is not that I wish not to have a Rev controlling device, simply that if the MSD box would have no other benefit then there are other means to control RPM. The MSD #121-8728 Soft Touch Rev Control can be had for about $125, or about half the price of a MSD 6AL-2. It would also be easier to mount (hide) since it has a much smaller footprint. Even more economical is the MSD #83647 Digital GM High Energy Modules with Rev Limiter. Both are options that I have been considering.
Again, I appreciate the technical info that you include in your posts.
Thanks - Kevin
1972 Firebird
3925 race weight
Old 02-02-2014, 03:55 PM
mgarblik mgarblik is offline
Agree with Tom on all items. I would add that the MSD on a nearly stock engine would possibly have a slight benefit if the carb. was not tuned perfectly at all RPM ranges it will be run at. The key is one good spark at the exact time it is needed. At lower RPM's where an MSD provides the multi-strike, there is a better chance one of the strikes will ignite the mixture, where a stock ignition will just deliver a mis-fire. The MSD as Tom mentioned, does have the advantage of higher amperage also. Bottom line, if your engine is perfectly tuned, there is no advantage to an MSD in your application. The benefits of a rev limiter should also be considered.
Old 02-02-2014, 04:18 PM
cgeise's Avatar
cgeise cgeise is offline
On the digital box's you have the ability to tune your timing curve to suit your needs -- along with multiple rev limiters
Old 02-02-2014, 04:21 PM
66bonne's Avatar
66bonne 66bonne is offline
You don't need one for your application. I have an MSD box in my Catalina and it helps smooth out the idle.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 02-02-2014, 04:32 PM
Tom Vaught's Avatar
Boost Engineer
I personally run a "potted" Factory Looking Ford SVO Performance replacement ignition box. Because it is "potted" the chances of a failure due to vibration are ZERO.
It does have a rev chip slot (which I use) but for general info, the typical MSD module triggers about 300 rpm below the number on the module. Would that make a difference on my street car. probably not.
Tom V.
Old 02-02-2014, 05:50 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
How low compression? Those cams need 10 to 1 and some stall speed. Sounds like you may be looking for a band aid. IMO.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 02-02-2014, 05:59 PM
Not looking for a band-aid. Car runs great for what it is. Just wanted to have a discussion about whether or not an MSD would bring anything to the party at this point.
1972 Firebird
3925 race weight
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I can tell you using an MSD distributor and 7A box my pump gas motor dynoed the identical numbers as a DUI HEI. No noticeable idle improvement either.
Skip Fix
Old 02-02-2014, 06:17 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
when I went from stock points to msd distributer, box and coil, start up, and idle were vastly improved. as well as improved throttle response.
Old 02-02-2014, 06:23 PM
Sun Tuned Sun Tuned is offline
Agree with T. Vaught except for the rev limiter deal, I could fill the next 3 pages with info about that deal.
That "potting" deal is the cats arse. just remember I told you guys that. Tom knows why....
What have you got now on your combo and how fresh is it??
Old 02-02-2014, 06:26 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I ran a Digital 6 for the flexibility and features.
Old 02-02-2014, 06:29 PM
KO KO is offline
MSD box only multi sparks at low RPM (under 2 or 3K I believe) They help keep the plugs from fouling at low RPM. The spark at higher RPM is single but more amperage and helps spark under high cylinder pressure.
1989 Automotive Hall of Fame Inductee
Old 02-02-2014, 06:59 PM
Default Requested Specs
Current combo is 455 .030 over, TRW flat tops, stock rods w/ARP bolts, stock nodular crank, Crower 60919 cam, degreed per Cliff's suggestion, 1.65 roller rockers, 6X heads that flow 244 @ .500, '72 cast iron intake gasket matched, Cliff's Q-Jet, 1-7/8 Hooker Super Comps, Flowmaster full exhaust with H pipe, 2500 stall, turbo 350, 3.73 posi, 275/60 drag radials, stock fuel pump, repop RA air cleaner with paper element, hood scoops are open, car was 3925 with me going down the track. Car went 12.94 @ 103.5. Best 60' was 1.65. See my other post about fuel system. Upgrades are coming. I realize the obvious shortcomings of this combo. I did not set out to build a racecar, but I made a few passes and now I am hooked.
1972 Firebird
3925 race weight
Old 02-02-2014, 07:01 PM
gman005's Avatar
gman005 gman005 is offline
Save the money you don't need it. Buy new tires.
Motor Daddy Motor Daddy is offline
A quote from the Innovate Motorsports SSI-4 manual:
"A capacitive discharge ignition system (CDI) uses a capacitor to store the spark energy. The capacitor is charged to about 400V and then rapidly discharged over the ignition coil's primary winding. The coil thus only acts as transformer and does not store energy (and can therefore be smaller). The advantage of a CDI system is a very high and fast rising spark voltage (less susceptible to spark fouling). The weakness of the CDI system is the very short duration spark, which might not be long enough to ignite the mixture. Multispark ignition systems try to overcome the inherent weakness by creating multiple spark pulses over some degrees of crank rotation to increase the likelihood of igniting the mixture. The distributor switches the spark voltage to the appropriate spark plug."
Old 02-02-2014, 07:20 PM
Tom Vaught's Avatar
Boost Engineer
Coil NEVER stores Energy. It is always a transformer (with the flux lines in the expanded position) and waiting for the circuit to open so that the flux lines collapse around the higher winding portion of the coil windings creating the high energy necessary to bridge the gap on the plug electrode to ground strap.
Tom Vaught
Old 02-02-2014, 07:53 PM
grandville455's Avatar
grandville455 grandville455 is offline
And that's How the fight started ,lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-02-2014, 08:20 PM
Airic1's Avatar
Airic1 Airic1 is offline
YOU NEED MORE GEAR!!!! Tell him about more gear Gman...
Baby's suck on Bottles, Real men get blown.
