Crazy front wheel wobble vid
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
Got some death wobble there. Sometimes called speed wobble.
Couldn't tell ya what's causing it specifically though. Suspension new, or just the problem new?
Jon B |
Stock steering, going to Smith racecraft front rack kit to try and fix.
Looks like a neutral or negative caster setting and some Bump Steer issues.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 01-25-2014 at 03:50 AM. |
The Following User Says Thank You to Blued and Painted For This Useful Post: | ||
Will be worth a solid tenth ( 0.1sec) & another 30+ years.
I'd check toe in and caster also.
That's one of the worse I've seen , I fixed mine with and Ed Quay damper
Camaros Firebirds Product Steering Damper Kit Click to enlarge Steering Damper Kit This weld-on kit is designed to minimize front wheel shimmy that occurs after a wheel stand. The kit is easy to install and allows the oil pan to center link clearance to be maintained. Steering Damper Kit $ 45.95 Steering Damper Only $ 24.95 Best price: $65.95 Reviews
84 T/A w/ IA 2 -- 505 N/A w/ Tiger heads / BOP intake. "Best time" 9.11@151.14/1.28 60ft. 77 Firebird formula 463 w TRW dome pistons w/ 4x's /edelbrock performer http://www.youtube.com/watch?v=KK163BxD9EY |
Looks like a bump steer issue. Do you have limiters on it? Make a bump steer gauge kit and check it with suspension at full extend. If stock Im betting its off 1/2" or more at full extend. Tying it down will bandaid the problem.
Mine did the same until I put a rack in it. |
Toe-in might help some but if a clearance issue then new components required asap. Ideal is tight clearances and toe-in with proper caster and camber on a stock suspension. A rack will not solve if Upper and lower suspension components are worn or cracked. I would check every piece of that front end including the steering box and then make a decision on if you need an upgrade. Tom Vaught
All of it is going in the can. Not phucking around with this one. Its dangerous and is scrubbing ET.
The Following User Says Thank You to john marcella For This Useful Post: | ||
And actuary years from the driver's life. Think you could sell that stock stuff... |
I would sell if someone wanted it. Its a flaming river manual box.
Good luck with your project upgrade. Check the frame upper and lower control arm mount locations for cracks too. Have seen them on F-Birds more so vs A-Bodies. Tom Vaught
Maybe try this? http://www.racecraft.com/index.php?m...oducts_id=1923
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I think it has to do with scrub radius??
The Following User Says Thank You to dda72 For This Useful Post: | ||
I think the tire's just scared from all the Pontiac power.
You got the poor thing worried. |
Im interested in your FR gearbox if it will fit my 69, can you provide a PN?
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
It will fit 69. 100 bucks
Is it the OEM style or the generic race version?
