I'm having a hard time finding hinge pins for my 67 GTO. the length is 2 1/2" from the bottom of the head to the part of the pin that is mushroomed out to hold the pin. The original plastic bushings are no good.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
I got mine from Pep Boys. They were on the shelf in the section that had all the "help"
type things in the red packages. I have no part # but if you measure yours you should be able to find them. If I reacall they came packaged with pins an a few bushings... this was a year ago or so. |
Got mine at Ames for the 66.
Are there REMOVABLE pins for our hinges?
You know, so I can take the DOORS OFF whenever I want. |
Machinist buddy of mine makes his own pins from valve stems of the appropriate diameter.
They don't wear out like the mild-steel junk the car came with. Removable pins implies no spring-assist detent on the hinge. Not my first choice. |
I would think the hardened pin would simply wear the cast iron hinge out sooner. I would think if you use the stock pins, at least you can replace them again, and the hinge body would be ok. But, these cars aren't like a lot of new cars that start to sag after 5 years of use. Doing it once would probably last another 40 years.
Jeff |
Well I'm going to replace the bushings with new bronze ones and figure I might as well put new pins in too.
