Old 12-17-2013, 01:15 AM
2manyT/A'S's Avatar
Default Body mount bolt torque?
This would be for the 4 subframe to body mount bushings.....
Using the reproduction ones not urethane...
I'm thinking 80-100 ft.lbs with lightly oiled (cleaned) threads?
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 12-17-2013, 01:47 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Service Manual specs out 85 ft. lbs. for the four body to frame bolts and 35 ft. lbs. for the radiator support. New GM subframe bolts that I have purchased over a decade ago had a stripe of loctite on the threads.
The Following 4 Users Say Thank You to Dens71TA For This Useful Post:
