67 Wipers wont turn off.
So when I got the 67 Tempest Wagon, the wipers were frozen. I got them broke free and lubed up. All is great!.
I drove in the rain on Friday from New Jersey to Connecticut. They worked fine as I used my hand as an intermittent wiper.. Started the car after a 3-4 hour rest and the wipers would not turn off. I removed the switch and the wipers still ON. I removed the plug under the hood to drive home. Switch, motor or wiring? Thanks Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Check and clean the contacts at the motor & the switch.
If they sit unused for long periods they will get funky. But it could be the sw has given up the ghost. My pump was sticking which will not allow the wipers to stop due to the continued rain
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
The windshield cleaner pump?
Had that trouble before and came down to bad ground to the wiper motor housing. Try a jumper wire from motor case to ground for a test.
Correct I pushed in the knob to clean my windshield and the bugger just kept pumping and the wipers kept flapping. My wife laughed her a$$ of while scrabbled to disconnect it Turned out to be dirty sw, cleaned it out of car with electrical spray cleaner and she was good to go! I don't used my wipers often enough so it just got a bit funky I guess. Now I make it a point to run/test all devices/switches at least once a month.
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
