Old 11-23-2013, 03:52 PM
bluesmobile bluesmobile is offline
Default Need thoughts on valve job
I just got my heads back from the machine shop, had a 3-angle valve job done, hardened seats put in the exhaust, new intake valves and seals.
When I got them home on the workbench, I saw a bunch of silica sand stuck to the head in multiple places (first picture), and a pile of sand in the bottom of the bags the heads were in (machine shop bags - heavy plastic clear ones). I was disapointed, and I thought I should take the heads apart and clean out the sand.
When I got the valves out I was shocked at the rough surface of the valve seat. Please see pic #2 and let me know if this is acceptable at all to run, or if I should take the heads somewhere else for another valve job.
Heads are 6X (95cc chambers), going on a 462 with a stump puller cam and rpm intake.
thanks,
Jeremy
ID:	344198   Click image for larger version
Name:	3 angle v2.jpg
Old 11-23-2013, 04:08 PM
frankyboy455 frankyboy455 is offline
About the sand, I've had a similar experience many years ago. I picked up the heads from the machine shop, and left them in the trunk of my car for a few weeks. Riding around with the car with all the shaking and bouncing, there was quite a lot of sand in the bag as well. This was not a good feeling...
Old 11-24-2013, 04:13 PM
Wild Bill Wild Bill is offline
I'm not sure from the pictures you even got what you paid for. The picture of the seats does not appear to show hardened exhaust seats installed. Seat inserts are a bright stainless steel color which would contrast with the gray of the cast iron.
The "sand" is glass bead used to clean the head prior to inspection and machining. However it does not look like the head was glass-beaded because you can clearly see carbon deposits in the chamber under the glass-beads.
If the heads do have seats installed that are not appearant in the picture I would definitely disassemble them and clean them before installing them.
Yes the seats are a little rough. You may be able use lapping compound on the seats to clean them up but may need the seats recut to remove the deeper grooving.
Bill
Old 11-24-2013, 07:11 PM
Schurkey Schurkey is offline
I, too, do not see hardened inserts for the exhaust seat.
I would take them to a different machinist and ask them to vacuum-test the valves/seats.
First Guess: They won't hold vacuum; need to be kissed with a stone.
Old 11-24-2013, 07:16 PM
455Darren's Avatar
455Darren 455Darren is offline
The 6X heads have factory induction hardened exhaust seats. No need to have any installed. I would find a different shop.....
Drivin' fast and takin' chances!!!!
The Following User Says Thank You to 455Darren For This Useful Post:
Old 11-24-2013, 10:00 PM
What happens if you grind through the thin hardened layer?
Old 11-24-2013, 11:53 PM
Yes the 6X heads would have induction hardened seats but those look like 1.77 valves not the stock 1.66 valves. Notice how close the 2 seats are intersecting at the center. Cutting the seats large enough for the big valves should also remove all of the hardened material.
Old 11-25-2013, 12:01 AM
I just got a set of heads back from my local cylinder head shop (That's all they do). I should post pics of them. Your heads look like mine did before I took them in. I would not be happy with that.
Old 11-25-2013, 08:15 AM
steve25 steve25 is online now
I see the exh seat incert, but there is a bigger problem other than the poor valve job and the bead blast remains in and on the head.
Yes, that Exh seat will expand at a faster rate than the rest of the chamber meat that the Intake seals on!
The big problem is that the exh seat incert extends into the main seat area of the Intake valve, and once the exh seat heats up and expands more than the rest of the cast iron around it the Inatke valve will then loose its seal at that portion of its seat.
If what I am seening from your pictures is true, you will have to now take the heads to a different shop and get seats installed on the Intakes also, and hopefull this shops valve seat cutting equipment will cut atleast the main seat will and not rip it up and leave the chatter marks that this current shops equipment did, total **** I am sorry to say!!!
Old 11-25-2013, 09:37 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Dull tooling (carbide cutters) or not truing up stones produce the results you are seeing.
I would remove all the springs, mark the seats with a black magic marker, and hand lap the valves in. If you don't have good contact all the way around, contact between the parts, and adequate margin, get them touched up so you do. I like stones for the touch up part of that deal rather than a cutter, as they polish at the same time and leave a seat that's easier to see when determining if you have adequate width, etc.
All the sets we get back have the valves and/or seats blued/marked where the shop doing the work checked the final product....FWIW....Cliff
Old 11-25-2013, 10:03 AM
What is adequate seat width, intake and exhaust?
I did spend a couple hours with a hand-lapper and some lapping compound. Seats in the head did not clean up much, but I could see the contact on the valve, and in some intake seats it was less than 1mm.
There have definitely been hardened seats installed on the exhaust side, no doubt about that. (it may have been hard to see in the pics)
Jeremy
Old 11-25-2013, 10:51 AM
CROCIE JR's Avatar
CROCIE JR CROCIE JR is offline
Horrible. I'm curious about all the other stuff, guide fit and clearance, valve tip height, did they really get magged, seat run-out and concentricity. Just stop and start over. The most you want to lap a valve seat is about 15-20 seconds max. I usually get a pattern to work with in 3-5 seconds. Any more than this and you are creating your own seat with a wooden stick!
Old 11-25-2013, 01:06 PM
For long term street us with unleaded,intake main seat width needs to a minimum of.055" with a 30 degree stock seat.
Exh seat width should be .080",the exh seat width can go down to .070" minimum if you are shotting for max flow with a three angle valve job,or limited usage as drag strip only,but you had better not have knurled guides or loose guides or used valves with little margin from being recut and trued up or the seat will burn thru at some point.
Sorry about the run on sentence!
Old 11-25-2013, 02:17 PM
I hear ya, thanks for your advice.
This was my 5th machine shop around here that either refused to work on Pontiac stuff (too old) or did bad work. Does anybody know of a good machine shop in the Metro Detroit area? Or Flint, or Lansing? Or Toledo? Its not a matter of cost or time, I just want it done right.
The seat widths are all over the map, from 0.040" to 0.130"...
Jeremy
Old 11-25-2013, 02:35 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Jeremy
It is a disgusting situation!!! Here is a man in the "Motor City" that has trouble finding a half decent machine shop! That area has been destroyed geopolitically......
I hope you find a good machinist, I just had to vent a little.
Karl
Old 11-25-2013, 06:01 PM
There's got to be a good Pontiac shop up there somewhere. There are some pretty knowledgeable members on this site that live in that part of the world. Tom Vaught, Dr. Eric Schiffer come to mind.
Old 11-25-2013, 11:36 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I too see the exhaust seat insert in there. The valve job looks like it was stoned to me. This kind of stuff drives me nuts. That's why I spend a long time blowing out every bolt hole and water passage, after I have flooded it with water. By the time I am done with them, they have been washed at least twice with every bolt hole and water passage blown clean and dry as many times so this doesn't happen.
Had a guy bring me a set of heads, all done by another shop in town, just like this, bagged up and all, just full of glass beads everywhere. Just like this. Not good.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 11-26-2013, 12:43 AM
Pontiac Performance Author
My first thought was "I can do a better job than that with my old Black &Decker "vibrocentric" and I don't do it fo a living" I did see the step for the hardseat.
Not sure i agree with Steve25 re: seat expansion. The Edel. heads all have overlapping seat , and no issues that I am aware of. Beads have to go. find a shop with a vibro table and have them shaken out real good after the next VJ
Old 11-26-2013, 07:19 AM
zephyrracer zephyrracer is offline
Jeremy
More Power Inc 616 785-8888 not Metro Det, great machine work, Sparta Mi
Gregg
Old 11-26-2013, 07:23 AM
So true, 60 years of socialism destroyed a great city, in the 60s Detroit enjoyed the highest standard of living in the world, it was a fun place to grow up in.
Gregg
