I'm going to do a light bead blast on the tail light housings I bought from Andre and am wondering what color I should paint the inside? ( the area that reflects the light)
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
It may not be "correct" but I painted mine with a rattle can of Chrome paint.
Remember no one is perfect. Everyone's butt has a crack in it! |
Spud, try the walnut media as it will do less harm to the parts. Not sure how it will work with rust, but I do know it's great for paint removal without hurting metal.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
The Following User Says Thank You to GT182 For This Useful Post: | ||
![]() Quote:
the housings really arent rusty, just arent very clean looking. I have access to plastic bead at work too that I can use.
I have tried a few different paints on the inner housings,
I ended up using flat white and am very happy with the ones I have done. They lights seem brighter and the red lens' really glow. You might give it a try.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
Plastic should work ok too. I was saying walnut as I've been using it to get the paint off a set of '79 WS Snowflake wheels and clean them up. No metal damage at all. Plastic 'might' be safer on thinner metals.
I have not done it but have seen many threads on the different boards I am on. ALL that have painted theirs WHITE have ALL said it made the lights much brighter.
