Old 11-10-2013, 08:56 PM
mchell's Avatar
mchell mchell is offline
Default running.....
well.....after a Looooooooooooonnnnnnnnnnngggggg hiatus......got it running again
see short clip of idle
KRE 295's....262/265 solid cam..11 to 1 ..93 octane
pretty smooth idle for a large cam......more to come
https://www.dropbox.com/s/m8a42tamcn...2018.32.37.mov
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
The Following User Says Thank You to mchell For This Useful Post:
Old 11-10-2013, 09:01 PM
67droptop's Avatar
67droptop 67droptop is offline
Sounds great!
Old 11-10-2013, 09:06 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Sounds awesome!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 11-10-2013, 09:27 PM
66bonne's Avatar
66bonne 66bonne is offline
Mike: that sounds baaaadddd !! Can't wait to hear it live !! Congrats for a job well done.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 11-10-2013, 10:43 PM
gold bird's Avatar
gold bird gold bird is offline
Thumbs up
Sounds good inside the car to.; ). Vary impressed with street manners.
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19
http://www.youtube.com/watch?v=6PaHbLnszS0
http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109
http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60.
Old 11-10-2013, 11:26 PM
66bonne's Avatar
Mike, Jesse, Wyatt: I think it's time for a party at Bradenton. I want to hear it in person !
Jim
Old 11-10-2013, 11:48 PM
David Holmberg's Avatar
Very nice Mike, congrats!
Old 11-11-2013, 12:51 AM
66bonne's Avatar
David: Maybe we can get you out there too !
Jim
Old 11-11-2013, 01:43 AM
I would love it, I just need to find the time to put the heads on and install the motor.
I would like to be there, even without a car, when Mike makes a pass!
Old 11-11-2013, 08:05 AM
grandville455's Avatar
grandville455 grandville455 is offline
Mike that sounds bad!! Your going to be flying now! Video of run needed for us winter people,lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 11-11-2013, 09:47 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Sounds great.
I agree not as choppy as one would expect.
I am guessing the 11-1 is smoothing the idle.
Old 11-11-2013, 10:07 AM
David Jones's Avatar
Amazingly smooth for such a large cam. Sounds great.
Old 11-11-2013, 01:42 PM
mchell's Avatar
Update:
pulls hard to 6500.....very little rpm drop between shifts....very hard to control in 1st and 2cnd.....no bobbles at all throughout the rpm range.......power brakes work perfect...runs at 170 degrees.... idles good
more to come..
excuse the nasty engine compartment.....its needs a cleaning after install!
Name:	2013-11-11 12.19.48.jpg
ID:	342708   Click image for larger version
Name:	2013-11-11 12.20.05.jpg
ID:	342709   Click image for larger version
Name:	2013-11-11 12.19.41.jpg
ID:	342710   Click image for larger version
Name:	2013-11-11 12.20.30.jpg
The Following 2 Users Say Thank You to mchell For This Useful Post:
Old 11-11-2013, 02:49 PM
mchell's Avatar
The solid is on a 112 lobe... Installed at 108 ICL....helps the idle and let's it pull rpm like a mad dog..
Old 11-11-2013, 02:50 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Originally Posted by mchell View Post
Update:
more to come..
Damn......That sounds bad ass!
Can you give us all of the cam specs including springs and rockers?
Karl
Old 11-11-2013, 04:19 PM
mchell's Avatar
Comp cams custom solid 262/265 on a 112 lobe
Intake is a 6009 lobe
Exhaust is a 6018 lobe
.638 lift on the intake , (.622 after subtracting lash)
.647 lift on the exhaust (.631 after subtracting lash)
Advertised duration 295/301
Comp 99893 springs, 1.87 install height
mchell's Avatar
Rockers are Harland sharp 1.65
Old 11-11-2013, 04:27 PM
66bonne's Avatar
Gee Mike...the motor still looks pretty stock to me !
Jim
Old 11-11-2013, 04:44 PM
Silver Judge's Avatar
Whoa, that's a pretty nice idle for a cam of that type
Sounds nice and nasty ~!
How big are the chambers on the KRE D ports ?
You mentioned power brakes work just fine, How much vacuum can you get out of this combo
What sort of initial & advance timing are you running ?
501 HP, 554 ft lbs TQ
Old 11-11-2013, 05:44 PM
mchell's Avatar
74 cc chambers
Running 30 degrees of total timing (15/15)
Haven't checked my vacuum with a gauge yet
