Why are aluminum heads made with Boss
Ok, can,t figure it out, drivers side head towards rear of head outside there are 2 bosses sticking out with usually a hole in them, makes for torqueing head bolts back there a pain in the butt plus ive never seen anything ever bolted there.So way are they there????
You would think they would of been milled flat against head. I know if heads come off again thats what im doing.Where there located i can,t see anything bolted on there. They are flat on the outside and sure you guys know what i mean.Funny you don,t notice these things untill heads are bolted on!! LOL. |
The ones for the AC compressor mounts?
Most are made so factory equipment will bolt on.
Definitely there to mount the A/C compressor.
Since there are no separate right and left side head castings there are unused mounting bosses on one head, same as factory iron heads from '69 and later. |
No offense, never seen a AC compressor mounted that far back to the firewall. Butt if you guys say so.ok
The compressor is mounted on the passenger side head, towards the front of the engine of course.
The point being the same casting is used for both heads, so one head has the boss located where it won't be used. |
I'm reading this question, and the response to b-man's reply, and I'm thinking to myself "you gotta' be sh***ing me, right?"
If you milled off those bosses then you will make that head basically a drivers side only head.
Then if you ever sold them to someone who needs the AC mount he would have to make sure to not bolt the hacked up head on the pass side. I'm sure that sometime in the future you will replace the head gaskets or had the heads ported then after all bolted on post some thread ""where did the AC mount go?""LOL Probably go through 5-10 posts wondering why the porter hacked up your pass side head head. Then someone will you that you did it to the head & then after 10 more posts trying to convince us that it was the drivers side head you did it too.... I cant wait LOL Both heads are identical. Place them against each other intake ports to intake ports & then they would be opposite of each other |
I personally use the bosses to mount the bracket for a charge air (water to air) inter-cooler. I am happy that the aftermarket put the things on the heads otherwise it would be a royal PIA to fab up a head stud type mount.
Tom Vaught
a/c mount
I use that boss on the back to run my rear cam driven a/c compressor keeps the front of the engine much cleaner and neater. I am currently applying for the patent on the rear cam adapter to run this compressor set up. LOL
The Following User Says Thank You to 68hotbird For This Useful Post: | ||
Can u be more specific on that mount and drive or are u being secretive due to your patent application? Which would be understandable.
Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
patrick
It's a shame to spend all that money for a patent when the application didn't include provisions for a fuel pump drive and remote distributor mounting - but maybe it's not too late to at least branch off and get the power steering pump back there.
Both bosses sticking out from the head next to sterrring column out of firewall. square with flat areas milled on them. Right straight up between no.5 & 7 plug.
That's the AC mount bosses.
Take that driver head and put it on the passenger side and those bosses are on the front, to mount the AC. Heads were made to fit either side of block.
Here's a schematic of an Ehead:
The 2 bosses on the right side of the pic are the AC mount bosses.
Patent application
The patent address the cam core needed for the drive system and the seal arrangement on the rear cam plug to keep oil leakage under control. There is also a key component to get the A/C compressor speed correct as the cam only runs half the speed of the crank. Hope this helps. LOL!!!!!
The Following User Says Thank You to johnta1 For This Useful Post: | ||
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
The Following User Says Thank You to Bud Lyons For This Useful Post: | ||
Buy the damn Prius and be done!
You need those holes for the mounting bracket(s) for the flux capacitor if you ever want to race into the future....
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! Last edited by Rob B; 11-11-2013 at 11:40 AM. |
Yes, but at the same time no
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
