Old 10-16-2013, 07:34 PM
soupman soupman is offline
Default Stroker crank clearance
I am installing a stroker crank in my 400 block. I had one area to grind to make the crank turn, but some of the throws are real close to hitting. Is there a minimum distance the clearance should be? I was thinking at least .015, any help?
Old 10-17-2013, 06:39 AM
steve25 steve25 is offline
.030"
Old 10-17-2013, 11:43 AM
Mr. P-Body Mr. P-Body is offline
Rule of thumb is .090", or about the thickness of a wire coat hangar.
The area needing attention should be the alignment "lug" at the front, where the counterweight hits it. Cutting it back 1/8" is always "good".
FWIW
Jim
