Old 07-07-2013, 04:24 PM
carcrazy carcrazy is offline
Default Drum brakes too tight
Working on my 67 GTO front drums (rears done and fine). New shoes, drums, studs etc. Even with the adjusters all the way in, the drum is tight going on and the wheel won't spin. Everything is seated properly. Any ideas? Could the new studs in the hub be slightly off (look ok)?
The Following User Says Thank You to carcrazy For This Useful Post:
Old 07-07-2013, 05:49 PM
LATECH's Avatar
LATECH LATECH is offline
If you have both secondary shoes on one side the brake will be tight or drum wont go on.
Did you have primary and secondary on each side?
The Following User Says Thank You to LATECH For This Useful Post:
Old 07-07-2013, 06:22 PM
steve v's Avatar
steve v steve v is offline
Make sure the wheel cylinders are not rusty/sticking & holding the shoes out slightly. The shoes should touch the top anchor pin with the return springs installed.
HTH,
The Following User Says Thank You to steve v For This Useful Post:
Old 07-07-2013, 07:13 PM
Shoes touch the anchor pins, primary and secondary shoes are correct.
Old 07-07-2013, 07:35 PM
jmt455's Avatar
jmt455 jmt455 is offline
Adjusters completely retracted?
If everything else is OK, you might want to check the I.D. of the drum. Might be under spec.
The Following User Says Thank You to jmt455 For This Useful Post:
Old 07-07-2013, 07:59 PM
Adjusters are completely retracted. I plan on switching sides for the drums/hubs to see if there is any discrepancy. I've done quite a few brake jobs and never ran into this.
Old 07-07-2013, 09:31 PM
steve v's Avatar
You may compare the shoes to your old ones. I don't think they reline old shoes anymore like the good old days. It must be cheaper to have a third world country manufacture a new shoe than to get your core, clean & reline it.
There's a good chance somethings out of spec on the shoe if everything else is good. You're using the same drums as you had on it before correct?
Old 07-07-2013, 10:43 PM
New drums.
Old 07-08-2013, 01:21 PM
chiphead's Avatar
chiphead chiphead is offline
Do any of the wheel stud's "knurl" stick out past the hub? That can contact the drum and cause it to cock into the shoes. Everything was new but it would lock up when I installed the wheel. WTF? Turns out the aftermarket wheel studs would keep the drums from seating properly on the hub. I had to enlarge the holes in the drum so the lugs would clear.
The Following User Says Thank You to chiphead For This Useful Post:
Old 07-08-2013, 11:25 PM
59safaricat 59safaricat is offline
I had the same the problem with my '59 when I put new brake material, drums, wheel cyl, hardware...ect. I think most suppliers are applying thicker amounts of material on in order to last or surpass their specified warranty period. I barely got my drums on (especially the rears) and they dragged for a while until "breaking in."
The Following User Says Thank You to 59safaricat For This Useful Post:
Old 07-09-2013, 05:09 PM
Will be checking the studs tonight. These are aftermarket studs that are slightly different than the originals.
My back brakes went on without an issue.
Old 07-10-2013, 09:26 PM
Swapped out the hubs to make sure it wasn't an issue with the studs-still a no go. Put the old brake drums on and they fit fine. Either the new shoes are too thick or the drums are. Guess I'll have the new drums turned.
Old 07-13-2013, 06:15 PM
Had the drums turned slightly and that did the trick!
Old 04-07-2014, 03:18 PM
61 389-348's Avatar
61 389-348 61 389-348 is offline
I know this is sort of an old thread, but I've noticed the same on my 63 Grand Prix, and especially with my right rear brake. I prefer to adjust and balance side to side and front to rear with a temperature gun. My right rear is running about 25 - 30 degrees hotter than my other drums. I manually adjust the star wheel all the way in and go for a 30 minute drive and the adjuster keeps backing it back out until it's too tight. And then it becomes rear lock sensitive like an 80s GM car. I'm just about ready to remove the auto adjusters, but thought I would ask first to see if there's anything I'm missing.
Edit: New relined rear drums btw.
The Following User Says Thank You to 61 389-348 For This Useful Post:
Old 04-12-2014, 06:44 PM
Do you have the correct adjuster? Is it installed correctly? It should only adjust in REVERSE. Should not adjust going FORWARD.
The Following User Says Thank You to Goatracer1 For This Useful Post:
