Old 07-07-2013, 10:53 AM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
Those hub caps are EXTREMELY rare! Beautiful ride - welcome to the dark side!!
Never trust anything that bleeds for five days and won't die.
Old 07-07-2013, 09:02 PM
ronstory ronstory is offline
Yes, the rareness of the original wire wheel hubcaps has been pointed out by the seller.
The sad thing I'm going to put front disc brakes on it so I need to move up to 15" wheels. So I'll end up boxing them since they are on the original option pull-list for the car.
Thanks,
Ron
1964 Catalina ragtop
Old 06-29-2022, 09:15 PM
Pmrockhead Pmrockhead is offline
Hi, I just purchased a 64 Catalina 2 door and can’t figure out how to tighten the loose antenna. It’s a manual but it appears there is no nut under the front fender, inside the door hinge, but a “scissor” looking locking mechanism that doesn’t tighten and the antenna swivels around
Old 06-29-2022, 10:56 PM
You are lucky it is a 1964 because ALL 1964 Pontiacs I have ever seen have the provisions on the engine to mount a later block mounted starter. Your car will have a transmission mounted starter but the holes are in the block. All later transmissions ( T350-T400 or OD) require a block mounted starter. You do not want to rebuild a "slim jim" trans.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Thread Tools
Display Modes
