Old 06-09-2013, 07:41 AM
63gpman's Avatar
63gpman 63gpman is offline
Default 65 Camber adjustment
I got into a good discussion with an old timer that still runs a repair shop in rural MN. We were discussing alignments on these old cars. He was just across the street from a Pontiac dealership back in the day and was one of few people with a decent frame rack back in the day. He was saying that he remembers having to pull the upper control arm mounting areas inward so that he could get the camber adjusted correctly w/out having a ton of spacers to adjust them. He said that this was back in the mid 60s and was having the dealership sending him work to get them adjusted correctly.
Looking at my tear down pics, the old frame had 4 1/8" spacers and the replacement had 3 1/8" spacers in them and I do not know if it was aligned correctly on either of them or not.
Have any of you heard of this? If so, what would be the correct spacing between the upper control arms? I have the engine and trans in the car now, but would be very easy to take it back out and adjust the frame a little to make it easier to adjust the camber if needed.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 06-09-2013, 10:18 AM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Seems like all the ones I have had have had a "healthy" stack-o-shims on them. I've never seen one on a car, but they did make aftermarket offset upper control arm shafts to make up for frame sag, so someone must have had problems.
I do know that to get the caster even a degree positive, you wind up with an inch of shims on the forward bolt and none on the aft. You might see if he has any ideas about pulling or relocating holes to get 3 or 4 degrees of positive caster, not that would be a sweet mod.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 06-09-2013, 11:36 AM
Deadhead's Avatar
Deadhead Deadhead is offline
I think this was more of an issue with pre-65 cars. I know they made the off-set bushings for '63-4 for this reason. I have never had an issue with it on my '66.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
