Old 04-20-2013, 05:24 PM
sweet73 sweet73 is offline
Default Frame connectors
Looking for a easy install set of bolt in frame connectors for a 73 Trans Am. Any suggestions on good priced set? Also plan on installing Caltracs,unless there are other cheaper and just as effective solution to prevent wheel hop.
Old 04-20-2013, 10:47 PM
GTOLou GTOLou is offline
I am a fan of protouring f-body connectors.
Also, you might just get good rear springs to fix your wheel hop.
Old 04-20-2013, 11:21 PM
chitownTA's Avatar
chitownTA chitownTA is offline
I put tubular frame connectors on. I think from RARE. Fit was nice just a bit tight on the rear rail.
I went with cal tracs to fix my wheel hop. I had a brand new set of 5 leaf springs that would rattle everything loose in the car when it tried to hook at the track. They were easy to install. I had to replace the front bushing with a supplied solid one and bolt the new spring pad up. Just loosen them up for street driving and you won't notice they are installed.
Old 04-20-2013, 11:55 PM
David Holmberg's Avatar
Cal tracs are much better than the slide-a-links.
My car launches great for no power or gear. 1.4 60's
Old 04-21-2013, 12:12 AM
ta man ta man is offline
CE bolt in frame connectors work well..easy to install other than possibly spinning the subframe cage nut.I also weld my front section where it meets the frame rail.
Old 04-21-2013, 12:20 AM
70UglyBird 70UglyBird is offline
I know they aren't really what you asked for but I will say the DSE sfc s are very nice. Make the floor connected and loose no ground clearance. There are some install pics on the first page of my build thread..
http://www.pro-touring.com/showthrea...rebird-Project
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
Old 04-21-2013, 01:52 AM
wheelspin's Avatar
Arrow Me too...
Originally Posted by ta man View Post
CE bolt in frame connectors work well..easy to install other than possibly spinning the sub=frame cage nut.I also weld my front section where it meets the frame rail.
Another bolt-in CE user. I ended up welding both ends of these units while the '72 TA was secured on a frame rack after discovering that the bolt holes had elongated from the bolted connectors moving against the sub frames. The single best mod that you can make on a sub-frame style chassis, IMO. The DSE and BMR units that install partially through the floor pans are a better choice since they offer a nice increase in ground clearance over the CEs.
Les Iden
Old 04-21-2013, 02:59 AM
blueghoast's Avatar
I use the bolt on slapper bars the cheap ones.
My cars 60 ft times are 1.40-1.41 you can pick
them up at swap meets for cheap. The ones on
my car only cost me $5.00 now thats cheap.
GT.
Old 04-21-2013, 08:39 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
I just finished this project yesterday on my 76. Used the Jegster subframe connectors from Jeg's and Lakewood slapper bars. I had to cut off the inside rear downturn on the Lakewood bars to get the rear stabilizer bar mounted, but that was an easy fix. Both the connectors and traction bars went on easily. Welded the connectors on at both ends. This makes the frame a solid unit and can be cut out later if need be. Used lakewood slapper bars for years on my 67 bracket car with good success (average 1.39 60ft.), and are a whole lot cheaper than caltracs. I attempted to put a set of CE J-bolt slapper bars on this car. I spent a full day on them and never got them to go on. The J-bolts would not line up with the fixed brackets on the bars. The older Lakewoods(67-69)had a clamp that went on the front J-bolts and they worked great. Now I am stuck with these JUNK CE slapper bars that won't fit. I bought them new for $75 from an individual who decided not to use them. Thought I was saving money. Plan on contacting CE about the non fitment of their bars.
Old 04-21-2013, 08:42 AM
cnc's Avatar
cnc cnc is offline
I have a set of Frame connectors as well as Solid Body mounts from PTF Still need to install them
I also have a set of Slide-A- Links still to install as well...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 04-21-2013, 08:57 AM
form74's Avatar
form74 form74 is offline
I have the Alston frame connector's on my formula, they can be bolted on or welded, I bolted them on but had to drill holes on the frame rails to do this.
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
