Shaft Rocker Options
What options did you choose/not choose and why?
Rocker Shaft Brand Spring oilers Steel rockers Shot Peened Lightweight Needle Bearing Tips Aluminum Stand Ratio Adjuster
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
T&D, I live close to them & friend with them. Not to mention they are superb rock shafts.
Jesel, it is what comes with the Tiger heads. Quality product. Mine came with 1.9 rockers. Although the trend nowadays is to go as big as you can on the cam (lobe lift), there by having to use less rocker ratio.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Already have the cam and 1.65 ratio is about all I'll need.
Any pros/con to going with a spring oilers?
I've got hand me downs from other PY members. Bought a new in box Crower SS 1.6 for E heads-They had not changed it from iron heads so the valve spacing was wrong. They sent me a new set up still not the right pushrod offset for the pushrod holes but finally got it down. The SS do look better than the bulkier aluminum Crowers or the TD I picked up for HP heads. Haven't test fit it yet.
Jesel is doing the rockers on the 620 V motor. Head is at their shop now.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Had both - prefer the TD
In your case, who made the choice?
Any reason not to go with spring oilers?
I'm having Jessel make the rockers for one of my RAV projects. I just received the prototype this week. I need to mock up and confirm, I was waiting over three months to get to this point.
IMO, Jessel is the best rocker systems out. Calvin Hill Hill Performance 708-250-7420 |
X2! I've used both and the Jesel's get the nod for me.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Jesel is absolute high quality. We chose them because they had rapid prototype capability. Their custom shop had the ability to easily convert our unigraphics files to machine path. They were interested and engaged in our project which is super important if you ever want it to see the light of day. We ended up with a 1.85 ratio, steel exhaust rockers because of the extreme cylinder pressure in a nitro engine, aluminum intake arms to save some weight and cost. Took several prototypes to get the geometry perfect and to get 1/2" push rods to not rub the pushrod tubes, but I am very happy with them. I have used T&D also. They are high quality and actually use a larger diameter shaft than Jesel. The reason I didn't go with them was I got the feeling at the PRI show and on the phone that they didn't buy into the nitro Pontiac project. They gave me the vibe that they would "do me a favor" and take thousands of dollars from me to make the stuff. Also, being 3000 miles away was a factor. If you have a solid contact with T&D the products are top notch.
