Old 03-15-2013, 12:24 AM
slowandpoor's Avatar
slowandpoor slowandpoor is offline
Default 4 speed manual for a mid 11 sec street strip car
Will the Richmond T 10 hold up to a mid 11s street strip car. It will see mostly street action in a 68 GTO. I had a M22 behind a 455 68 firebird but you crossed your fingers everytime you dumped the clutch.
Old 03-15-2013, 08:51 AM
tom s tom s is offline
There was a special ST-10 made with hi nickle gears,steel midplate and iron case with I believe a 2.68 first gear.That would be my choice.If not one of those get one with the highest first gear like the 2.43.The lower the first gear(like a 3.42)the weaker the trans.Tom
Old 03-15-2013, 10:40 AM
brut4s's Avatar
brut4s brut4s is offline
How about the Muncie super case?
Old 03-15-2013, 10:55 AM
JoePapa's Avatar
JoePapa JoePapa is offline
If you didn't buy another transmission yet and want to not worry about the Munchie, buy the autogear case and iron midplate. I had those two plus the aftermarket M22 wide ratio gears and would launch my 3800 lb race weight beast at around 5-6000 rpm with and without nitrous and didn't have issues with the tranny. The clutch couldn't hold but the trans did great once I did the above mentioned upgrades. It's seen 10's in my car and with spray we dyno'd 550 ish at the back tires.
PS - obviously there's no overdrive with the Muncie so....
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 03-16-2013, 01:42 AM
Thanks fellas
