Old 02-10-2013, 10:42 PM
LATECH's Avatar
LATECH LATECH is offline
Default Head Gasket set with .......
I need head gaskets for my 400 build. It is decked to .005. (verified )
The Fel Pro Q1016 head gasket is .039 compressed thickness
The fel pro Q1018 Head gasket is .041 compressed thickness.
Dont want to spend more than I need to for a head set.
Question is ....: what fel pro complete engine set has these head gaskets in it?
Heads are from a 1972 so proper intake set comes into play also.
The gaskets are available seperate, but the whole kit will be a bit less expensive...I hope.
Old 02-11-2013, 12:54 AM
WDCreech's Avatar
WDCreech WDCreech is offline
Latech, I don't know if it is still this way, but quality gasket sets, incuding Fel Pro, used to have the numbers of all of the gaskets on the back of the package.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 02-12-2013, 08:37 PM
tooski tooski is online now
Fel pro Q2806 from Summit has the 1016 head gasket. $139.95
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 02-15-2013, 09:38 AM
Lee's Avatar
Lee Lee is offline
I prefer the kits with the 8518 head gasket. I've used dozens of them without a problem.
I've seen too many 1016's that don't seal the water passages. Maybe they've fixed that problem FINALLY, but I'll stick to the $65 gasket sets as long they keep working.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 02-15-2013, 08:07 PM
LATECH's Avatar
OK.. thanks Fellas. I have something else to research now .
