Old 02-09-2013, 09:26 PM
mchell's Avatar
mchell mchell is offline
Default fuel pressure at full throttle(video)
just for giggles......couple of squirts on the throttle to show what fuel pressure does at full throttle...slow street car with 1/2 Robmc fuel pickup, mallory 140 pump, stock 3/8 lines from pump discharge to Robmc regulator(deadhead)......QJET and RPM intake....rolling start at 25 to 30mph....less than 1/2 tank of fuel......275/60/15 tires
see link
http://youtu.be/RdJeSVpl9tc
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 02-09-2013, 11:00 PM
66bonne's Avatar
66bonne 66bonne is offline
Out racing in the neighborhood again, heh, Mike !!
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 02-09-2013, 11:32 PM
se428bandit's Avatar
se428bandit se428bandit is offline
I wish i could get my car to respond like that.
Old 02-10-2013, 02:16 AM
goatman65's Avatar
Wish we had weather like that here. I had to watch the vid twice. First time i watched the tach,second time i watched the tach and pressure.
Now my question, since you have 3/8 line are you really gaining anything with the 1/2 pick-up?
Maybe i should ask in one of the other fuel pressure threads.
Old 02-10-2013, 03:51 AM
Tim Corcoran's Avatar
An electric fuel pump is great at pushing but not good at sucking (kind of like my ex-wife). So by going to a larger size fuel line from the tank to the electric pump helps the efficiency of the electrict pump considerably.
Tim Corcoran
Old 02-10-2013, 09:34 AM
Icefan71 Icefan71 is offline
Where did all those donuts come from when you 1st pulled out onto the road?
1972 Pontiac Lemans 350 Qjet Summit 2800
Old 02-10-2013, 10:00 AM
PontGuy's Avatar
PontGuy PontGuy is offline
...slow street car with...
Don't know about others but I started watching the vid expecting something else entirely. Sounds really mean!
Approx 5 psi at the carb at shift point seems pretty good to me pulling that hard. Going to see at least some pressure loss with the fuel flowing that fast. As long as it keeps the bowl full, right?
Interesting that the lowest pressure seems to be after the 1st gear shift when it is digging into 2nd, then catches up by the 2-3 shift. Wouldn't have expected that.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 02-10-2013, 10:11 AM
66bonne's Avatar
Don't be taken in by Mike's comment of "slow street car". His Goat is not only drop-dead gorgeous but also deadly consistent at the track with ETs rarely varying more than a few hundredths.
See ya at the track Mike.
Jim
Old 02-10-2013, 10:25 AM
grandville455's Avatar
grandville455 grandville455 is offline
Put that thing away it's winter time! ... Nice run's, How far does it drop at the track with excellent traction? Shifts nice too , conv looks and sounds to be a tad tight yet
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-10-2013, 10:32 AM
mchell's Avatar
Good eye....cool to see it side by sde like that....basically why I posted, you can see, as we'll as hear what the engine is doing........may help others
my take. : the first run was generating more wheel speed ( spin)..so it dropped more....on the second squirt it stayed relatively steady ( less spin )..after catching up to the tires the pump gains, then steadies out...listening to the engine, it did not seem to care that it dropped to that level and after catching up it stayed steady
At the track, if I keep the tank at least half full it does not exhibit that drop.....probably because I am not generating the big initial wheel speed until I get up in the rpm range, but by that time the pump has already recovered and will keep up
Old 02-10-2013, 02:38 PM
ta man ta man is offline
With my 1/2 inch pickup I need at least a half a tank of fuel or the pickup gets uncovered.I used to run the same fuel system 140 Mallory pump stock 3/8 lines also was good for high 11's at 114/115..but upgraded to all 8 AN lines and fittings and the car picked up mph and et runs mid 11's with traction at 116/117 in the middle of summer.
Old 02-10-2013, 02:45 PM
Tom Vaught's Avatar
Boost Engineer
I ran a 1/2" line many years ago with a Modded 1/2" Pick-up to a GOOD Electric Fuel Pump, and then to a HP mechanical fuel pump. The fuel tank pick-up was longer and went to the rear center part of the tank. With the engine I had I could run 11.55 at 117 best times with a 64 GTO chassis. I always tried to run at least 1/2 tank but "ran out of gas" a couple of times with the gas level too low on the street to cover the rear pick-up.
Tom Vaught
Old 02-10-2013, 02:58 PM
mchell's Avatar
Good to know.....I am headed in that direction as well
Old 02-10-2013, 03:02 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Cool vid! I see a similar drop on my system. I've got my bypass regulator set to 6lbs, and will drop to about 5lbs at WOT at high rpm. I don't get the pressure "creep" any more since I went from deadhead to a bypass reg. So my fluctuation ranges between 6 - 5lbs. I'm running a holley hp150 pump sumped tank and 1/2" lines.
You may be able to set your regulator down a bit and still never see your pressure drop below it's current low point, or "low water mark". May avoid some unneeded higher pressures at the stop light/drive through without effecting max flow because now your max flow pressure is below your regulator setting.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 02-10-2013, 05:41 PM
Tom Vaught's Avatar
Boost Engineer
Holley Carburetors were designed to run at 6 psi for most applications.
When the engineers felt they needed more fuel into the bowl they upped the needle/seat size, not raise the fuel pressure.
Tom Vaught
Old 02-10-2013, 09:16 PM
gold bird's Avatar
gold bird gold bird is offline
Thumbs up
so adding a 1/2"line the rest of the way , will the pump keep up with the added volume if it was a holley blue pump ? nice car mike :}
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19
http://www.youtube.com/watch?v=6PaHbLnszS0
http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109
http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60.
Old 02-11-2013, 12:16 AM
66bonne's Avatar
Jesse: have you been encouraging Mike to street race !!??
Jim
Old 02-11-2013, 08:23 AM
gold bird's Avatar
not at all Jim we do that at street heat at the track .
Old 02-11-2013, 08:47 AM
gold bird's Avatar
like this just looking to see if my holley blue pump will keep up with the 1/2" line all the way to carb . good or bad time will tell see you at nmca Jim ?
Name:	wyatts phone 3 201.jpg
Old 02-11-2013, 08:44 PM
Tom Vaught's Avatar
Boost Engineer
Maybe, IF you take it apart and clean the screen really good. Maybe, IF the vanes are nice and loose and fly out properly to make fuel pressure. Maybe, IF you use two of the tiny little Blue Regulators (one for each bowl) to feed the carb bowls. Maybe, IF you install a decent hot wire to the thing vs using 16 gage wire to power the pump.
Course that does nothing if the blue pump is trying to suck/push fuel thru a 5/16" fuel tank line.
Tom Vaught
